1988 Half ton straight six F-150, I think...
Old 02-13-2015, 01:30 PM
Lee527's Avatar
Lee527
Lee527 is offline
Hi all. First post here. Recently bought this and all I know about vehicles is how to change oil, tires, and when it's time to call a mechanic. Can someone tell me what I have here and if $1600 was a fair price. Thanks.
Old 02-13-2015, 01:32 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
F150 2WD. Not much else can be known from info and pics.
Old 02-13-2015, 01:45 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
post a pic of the door tag and that will tell us a ton that we can tell you.
Trav
Old 02-13-2015, 01:46 PM
Lee527's Avatar
Lee527
Lee527 is offline
Some pics of the motor
Old 02-13-2015, 01:50 PM
88n94's Avatar
88n94
88n94 is offline
How many miles are on it, as far as you know?
Old 02-13-2015, 01:52 PM
Lee527's Avatar
Lee527
Lee527 is offline
Door tag. Got to run to work so ill check back in later..
Old 02-13-2015, 01:53 PM
Lee527's Avatar
Lee527
Lee527 is offline
Either 94948 or 194948. Odometer only has 5 digits, sits hard to tell..
Old 02-13-2015, 02:11 PM
Redneckfordf2502002
It has 3.08 open differential gears. One wheel wonder! LOL
Trav
Old 02-13-2015, 03:20 PM
miguel.in.az's Avatar
miguel.in.az
miguel.in.az is offline
Looks decent, 300 inline 6 is super reliable and easy to work on. Automatic or manual trans?
Old 02-13-2015, 04:29 PM
Redneckfordf2502002
Trans code T I believe is T-18 but don't quote me on that.
Trav
Old 02-13-2015, 05:31 PM
Lee527's Avatar
Lee527
Lee527 is offline
Manual. 5 speed. What do you mean about the gears and T-18 Trav?
Old 02-13-2015, 06:07 PM
Redneckfordf2502002
I must be wrong then because T18 is a 4speed.
The gears are in the rear end. Not sure how to explain everything.
Trav
Old 02-13-2015, 06:37 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Trav
Transmission Code "F" should be a T-18 4 speed manual transmission.
Old 02-13-2015, 06:41 PM
Redneckfordf2502002
Then if it is a 5 speed somebody must have swapped a M5OD (only gain is Overdrive but not the strongest transmission from my understanding) or a ZF5 (which in my opinion is the best stick shift for these year trucks).
More then likely the M5OD to get away cheap or gain overdrive.
Trav
Old 02-13-2015, 08:32 PM
Lee527's Avatar
Lee527
Lee527 is offline
I did some googling for the difference between open diff and limited slip. My basic understanding is "it ain't no racetruck" lol. Which is fine, i just needed something to get back and forth to work and maybe take a pretty redneck girl camping in from time to time. Thanks for all the replies fellas, its been helpful!
Quick Reply: 1988 Half ton straight six F-150, I think...
