74 f100 factory vacuum and emissions diagrams (302)
Old 02-13-2015, 08:59 AM
Matthewfriezf100's Avatar
Matthewfriezf100
Matthewfriezf100 is offline
I have a 74 f100, and I'm one of the crazies who wants to put the vacuum system back together the way the factory did it. It is a 74 f100 with a 302, carbon can on frame. I cannot find a diagram anywhere.
Old 02-13-2015, 09:01 AM
Matthewfriezf100
So far...
This is what I have so far from just guessing...
Old 02-13-2015, 03:42 PM
bkaul's Avatar
bkaul
bkaul is offline
This isn't the original factory diagram for a '74 F-100, but in case it helps here's one I modified from an '83 Mustang (by deleting the smog pump system) for the engine I'm dropping into my '74 F-100. I color coded the EGR green and the spark advance yellow, for my own convenience.
For an original 2V carburetor setup on these trucks, I would make the following modifications to the above:
- Ignore the second charcoal canister/purge valve/bowl vent solenoid, since the 2 barrel carb only has one fuel bowl
- Ignore the second air cleaner diverter valve since we don't have a dual-snorkel air cleaner
- Ignore the "VCS" vacuum switch
- Ignore the heat valve circuit unless you have a vacuum-controlled exhaust heat riser setup in place
- Plumb the brake booster (if applicable) and HVAC controls (if applicable) directly to manifold vacuum
Old 02-14-2015, 12:50 PM
bkaul's Avatar
bkaul
bkaul is offline
Old 02-15-2015, 01:50 PM
benbuilder's Avatar
benbuilder
benbuilder is online now
vacuum
Subscribed for future use
Jarbl
27
12-17-2017 12:14 PM
JakefromStateFarm
02-12-2016 03:41 PM
wintertruck87
28
11-21-2014 10:34 AM
mhwessel
05-17-2013 06:17 PM
gtuttle
01-22-2009 09:04 PM
Quick Reply: 74 f100 factory vacuum and emissions diagrams (302)
