Leaking out of passenger grab handle
I've just purchased a 2013 F250 Lariat crew cab. In the car wash I had quite a bit of water coming our of the passenger handle on the a pillar. I've researched this site and all I've found is 3rd brake light, sunroof and the Sirius satellite antennae leaks. I don't think it could be any of those. I don't have a sunroof, the third brake light is in the back and the antennea is on the drivers side. I'm thinking window seal or passenger door weather seal. Any other ideas?
on
Water Leak
I don't know if this affects the newer SD's, but early SD's has problems at the pinchwelt at the top of the doors. Pull the main front door weatherstrip, and check where the roof panel meets the door opening panel. The fix was to apply silicone sealer at that joint, let it dry, and then reinstall the weatherstripping. Unless Ford changed the design, the door main weatherstrip just pulls off of that pinchwelt. There was a TSB about this problem--it was dated around 2003 or 2004. Let us know if that was the problem.
RON
Crystal
Soak the cab down using a spray bottle with a mix of dish soap and water in it. With the HVAC fan blower on medium to high and the windows rolled up tight start spraying around the suspect areas. You will see it bubble. Keep in mind these cabs are not 100% water tight so you will see various leaks at the door seals etc...but there should be none on the roof or windshield seals. Said leak should show its ugly self right away. Id be suspect of the windshield and door jamb upper seals. Let us know if you find n fix it.
I know this is an older thread but I actually have the same problem on a 2012 F-350 that has less than 17K miles on it and is garaged most of the time. I only noticed it recently when I had to drive it on a rainy day. Unfortunately the truck went out of warranty in March. I'm wondering if the OP ever figured out the source of his leak.
I find it horrible that in 2016 these trucks are still leaking. Most of the time it's the third brake light and Ford continues to ignore this issue and not fix it after what fifteen plus years? My 2004 never has/had a leak but I replaced the third brake light seal with a better one off of ebay. Just a shame really
Crystal
Same deal on my 11. Puddle under the drivers side sill. Third brake light was the culprit. Replaced last year so far so good, dry floor. To say that its has been raining here is a gross understatement. Sufficiently tested for sure.
I'd get this into the hands of your dealer, CTYankee; I know they'll want to get this leak dried up for you. Keep us posted on what you find out. I'll be here if you need help after getting a diagnosis.
How frustrating, xr7gt390; let's see what I can do to assist. How many miles are on your truck currently?
Crystal
Crystal
