Problems with tires 1" taller than stock?
Depending upon if the aspect ratio decreases (e.g. 70 > 55), or the tire rating changes (e.g. P > LT), etc. ...
-click- the pic'
Goth 150
< This space intentionally -blank- >
- speedometer will be off by ~4% (too slow). *odometer will be off and unless there is compensation calculating MPG will be askew (e.g. PCM flash).
. - rolling resistance will increase. *less MPG
. - wheels (rims+tires) will be heavier. *less MPG
-click- the pic'
Goth 150
Went from the stock - approximately 32 inch tire to Yokohama Geolander at a fraction under 33 inches. Couple things I noticed right off. The mpg's get slightly lower fuel mileage indication. Not really lower because the tire is slightly taller which results in less revolution/miles indicated over the tank of gas. Seems to show about 1/2 mpg. The only other issue I noticed (probably seat of the pants gut feel) was slightly more body roll during turns. This may be due to deeper tread depth and softer compound tires than the original. Again, this was just my personal butt feel.
Getting away from the OEM tire, mine are quieter and have better traction. An inch is no issue. enjoy.
I upgraded from a stock Goodyear 275/65/18 to a 285/60/20, with Duratraks, when turning very hard left, the driver front tire barely rubbed on the inside plastic splash gaurd, i trimmed it about 1/2 inch and all is well...If i would have stayed with the 275, probably wouldn't have rubbed at all. Mileage changed from 18.3 to 18.2
Go here Tire Size Calculator - Compare Two Sizes
Put in your existing tire size and put in desired new tire size. It can make a difference. Your Transmission Control Module (TCM) is sensitive to tire size. It makes a difference in shifting.
I noticed it when I changed tires to a slightly smaller size. If I was going about 30 and slowed to almost a stop then applied the accelerator just slightly. I would get a harsh shift. It was hanging in third and then jumping down to first when applying the gas no matter how gently. A TCM adjustment fixed the problem.
derekmj64
01-22-2013 11:11 PM
