Glen-L DIY 9' Camper Cabover - Ford Truck Enthusiasts Forums
Old 02-04-2015, 08:32 PM
caliRangerXLT's Avatar
caliRangerXLT
caliRangerXLT is offline
caliRangerXLT is starting off with a positive reputation.
Has anyone heard of this company? Are they still in existence? This is awesome!! Camper plans: Cascade design 9' truck camper
Old 02-05-2015, 06:47 AM
Thunder:Raven's Avatar
Thunder:Raven
Thunder:Raven is offline
Thunder:Raven is starting off with a positive reputation.
That looks like it would weigh 5,000#. It's beautiful in clear wood though. Good luck
Old 02-05-2015, 09:40 AM
caliRangerXLT
Actually,
Dry weight (estimated) 1400 lbs.
Old 02-05-2015, 11:22 AM
Arbiter's Avatar
Arbiter
Arbiter is offline
Arbiter is starting off with a positive reputation.
Click over to their home page from that link you gave, they have an email listed, you may want to contact them for more info on those units.
Old 02-05-2015, 02:02 PM
whtwolf's Avatar
whtwolf
whtwolf is offline
whtwolf is starting off with a positive reputation.
I found another page from this company that has a working link to an ordering page.
Glen-L RV Plans | Glen-L Boat Plans
Old 02-05-2015, 06:29 PM
co425's Avatar
co425
co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
That's pretty cool. They have travel trailer plans too. I'd love to build one, especially since new ones are ridiculously priced.
Old 02-06-2015, 12:19 AM
RumRunner78's Avatar
RumRunner78
RumRunner78 is offline
RumRunner78 is starting off with a positive reputation.
Very reputable company, most known for their excellent boat plans. I've worked on a couple of their boats with friends, and the plans, etc, were all great.
Also, you should be able to build that to be well under 1000lbs!
Old 02-07-2015, 08:08 PM
caliRangerXLT
Thanks for the link! I was scared they were out of business. I emailed them this week and they promptly replied so it looks legit. Now to convince swmbo that we need a camper...
Old 02-07-2015, 08:28 PM
caliRangerXLT
Can I subscribe to this thread yet!?
Old 02-07-2015, 08:29 PM
caliRangerXLT
Thank you!
Old 02-12-2015, 10:40 AM
HoustonDave
HoustonDave is offline
HoustonDave is starting off with a positive reputation.
Rumrunner - just out of curiosity - what specifically would you do to reduce the weight from their dry weight estimate of 1400 pounds to 1000? That would definitely put this in range of a longbed F100 in that case?
Old 02-14-2015, 03:38 PM
caliRangerXLT
Dave, I'm not sure what the water capacity of this is guy is but say it's 40 gallons -- that's 333 lb right there. The point being don't fill the tank until you're parked and that's most of it. Other stuff would be to travel with only essentials in your truck. Either way you will probably want to beef up the rear leafs and add a sway bar, I plan on doing that to my 3/4-ton too. Make sure your brakes are up to snuff too.
Lastly, this article and site has a lot of good tips on how to match your truck with the right camper (even though it is geared at new stuff, the principles are the same): Properly Payload Matching a Truck and Camper
Good luck!
Old 02-14-2015, 07:09 PM
9thPony's Avatar
9thPony
9thPony is offline
9thPony is starting off with a positive reputation.
Looked up this sight and it has some pretty cool plans. My CC is a short bed so I don't think any of the plans listed would apply.
As for weight, it specifically states "Dry Weight" 1400 lbs for the Cascade mode which already assumes no fresh or waste water.
Old 02-15-2015, 01:32 AM
whtwolf's Avatar
whtwolf
whtwolf is offline
Good luck!
The weight they quote is the dry weight. This is what the camper weighs before being loaded. So if you take the plans for the Acapulco, it show an estimated dry weight of 1100 lbs. Add in water, food and other necessary equipment you can easily add another 4-500 lbs. That's going to get you closer to 1600 lbs if you fill the water tank before leaving (that's what I always did anyway, but I've done a lot of dry camping away from any camp grounds).
Anyway, this looks like a great way to get a nice camper that could last for years. I'm actually looking at the Dixie or the Cascade myself.
ssoundwave
2017+ Super Duty
145
09-07-2017 06:02 AM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
