What brand of ball joints are the best?
I got a 1988 f150 4x4 I'm trying to decide what ball joints to get I was originally gonna get some Moog ones but I got to looking at the and seem they don't have a intergraded rubber boot which is what I want for them to last longer and perform better. There just like the original ones and the tend to wear out quickly because of that. Anyway I was wanting to see what brand y'all use or have used and what y'all think is the best performing brand.
Raybestos service grade is reboxed spicer service grade.
Raybestos Professional grade is reboxed spicer Professional grade.
The Moog k80026 and K1895T balljoints I just purchased and installed this weekend were USA made.
The Spicer/Raybestos parts are assembled in USA, so possibly made overseas, then assembled here.
moog problem solver uses a metal gusher bearing
Raybestos Professional grade uses a composite (plastic) socket
Motorcraft is neither, its Taiwan and Mexican made stuff, with motorcraft stamped on it.
All three are greasable. I've read enough and been told enough gossip I'm setting some stuff straight.
Its your decision. Different designs. I went with moog, so far so good, Spicer/Raybestos pro grade is what would have come in it from the factory. The factory ball joints that come out of mine, had plastic in the socket, like the spicer/raybestos. XRF is a fairly new company, that deals with commercial trucks and equipment. They are sold online, but I've yet to hear much bad about them. Keep in mine with whatever joint you pick, installation and lubrication is the key to making them last.
Advance sells Moog. CARQUEST sells the Spicer/Raybestos parts. If you have time, you can get either much cheaper online from rockauto.com . I haven't found any yet for mine that are sealed, nor do I want any. I have a dana 44hd in my F250, same ball joints as a f150/bronco. You'll have to pack the bearings while your at it. Check this link out, it should help you some. 1990 ball joint replacement - FSB Forums
The Moogs I just put on my truck were made in USA and Canada. Some of the Napa Gold I've seen lately said they were made in China.
