37" tire on a stock height F350
#31
I got around to cleaning up last night, Decided to install the bolt in stems and the correct lugs arrived. I figured I would post this as the last one to this thread. I actually do think they will fit just fine. Once I pull the truck out, I will flex it and see if that holds true. Pic of all 4 on the truck. I sure like the look, and really don't think its necessary to lift the truck at all. I'll get center caps in the future for this set of hoops too...by the time I pull it out it will be well into spring.
Lastly. Does PMF make an RSK that work with these trucks with a a 6.0 cooler in them? If they could provide the shackles and hangers I'm sure I could fab my own cross bracing.
#32
I don't know about PMF, but I know SKY Manufacturing has one that is rated for use with an IC. Whether it's the 6.0 IC or not, I can't say, but it may be worth a call.
#34
#35
Thanks Brad. I wasn't sure if it would fit or not. I plan on doing this next winter. I'm going to have to lift the trailer too in order to do an RSK, and will have to do both at the same time.
You wouldn't have ever lifted a torsion axle trailer?? I really don't think there is much to it besides welding a 2" or 3" square tubing down the I beam frame and brace above the axle between each beam for regidity. Raise the trailer and reweld/bolt the axle mounts to the new 2 or 3" square tubing. Esxtend it a foot or two past the orignial mount location... not necessary
Sort of like how this dude did it...50 ft enclosed gooseneck trailer forsale - Pirate4x4.Com : 4x4 and Off-Road Forum
BUT NOT AS HALF AZZED!
I need to do it either way because with the 285s and the stock height I created that big azz dent clipping the rear of the bed on the goose... Right after I finished painting it. It rides excellent for going down the highway, but the trailer tail drags to easily anywhere else and the trailer does not sit flat as I'd like it too...loading the rear axle quite a bit.
Just pulling it up our slight drive way gouges the chit out of the ground with the rear casters. Simply not enough clearance anywhere off the highway. Stuck myself into multiple fuel stations before too.
Trailer is dove tailed and jacking the front way up it will still easily load a car without centering the vehicle pan just past the drop gate. I am not worried about gaining a few more inches...
#36
#37
Thanks again Brad, and GLWS on the CC!
deezdrama
08-17-2016 11:28 PM
ghunt
04-04-2008 06:28 AM
