Show Off your 09-14 F150s
#1051
Hawk, I had the same feeling when I went from an '01 with a 5.4 to my '10 with a 5.4. There is more room in the front of the engine compartment mainly due to the '10 having electric fans vs. a water pump mounted fan. It also looks like the motor sits a little lower but that might be due to the taller/square fenders that are on this generation. The next time I am outside, I will try to take a picture of the engine compartment of the '18 to post.
#1057
#1059
It has been awhile since I have posted in this thread. I had some operating issues with the aftermarket projector head lights that I purchased and ended up getting a different set under warranty because the ones I had were on back order for a few months. At first I did not really want the halo look and more so the 4 bulb style. After having them for a few months now, I really do like the look. I have also changes all of the exterior lights over to LED along with the map/dome lights inside. The interior ones have made a night and day difference at night time. Here are a couple of pictures of the new head lights.
#1060
Tiny,
Those actually do look quite good. I am not a fan of that strip of LED lights, but I do think the quad lamps look good. Especially considering how big the headlight housings are on this body style, it helps to have something more than a big solid plastic wall.
Looks like the low beams are projectors & the high beams are reflector type.... Correct?
Are all 4 lights on with the high beams or do the low beams shut off?
#1061
Tiny,
