226 draft tubes, G vs H series
A member here, 3twinridges, sent me a PM asking if I have an extra draft tube from a spare engine I bought from another member, raystasch. When I checked the cartons of parts I did not discover what I recognized as a draft tube (although I did see something similar). I have attached a picture of the draft tube that's used on the engine I'm building, but it is believed to be from a G series. My engine is an H series but someone could have attached a G series valve cover in years back.
For those with the 226 engine, does the attached image look like a G or H series draft tube?
I have two original 'H' engines (late '49 and a late 51) and neither draft tube looked like that. My tubes were separate from the cover and screwed onto it with one bolt. The tube itself is one piece.
Can't say what a G is supposed to look like, haven't seen one of those engines up close.
Tom
Tom
Tom
Tom
I don't have a lot of experience with the flat 6 engines, but I have reason to believe Ford made a lot of running changes, whether it was for application or engineering, to the draft tubes. I've got (had) a 51 and a 52 254 6's and they both have a different draft tube, and both were original.
Thank you, I have the tube, but I am coming up empty on the mid point clamp and oil pan bracket for the tube. The pieces I am looking for are parts 8556 and 6788 from the van pelt diagram. Thanks! Sorry to keep beating a dead horse on the draft tube, but I think it is important to get the oil condensation out of the valve chamber and avoid sludge and buildup.
Is that what it does? I thought it was a kickstand for holding the engine upright when someone puts one on the ground.
I'll keep an eye out for one for you, I frequently look for 226 parts - like the elusive water pump rebuild kit and phenolic layered carb spacer, etc.
Tom
Aren't all 226 parts elusive? I would equate finding the mid point clamp and the oil pan bracket equivalent to seeing a real live Yeti. I have found most all other parts! It's kinda good to experience that though, it keeps me from buying something even older than a 50 F1. Could you imagine finding parts for a 32 or a 37 year model, what a nightmare!
I have found a clamp and bracket for the 8 clylinder, I think I can make it work, but if someone has the 226 draft tube parts lying around collecting dust, I have a home from them!
Jonathan
Jonathan
As always, this site is always a flurry of knowledge. I have learned that I didn't even have the correct draft tube on my old engine, and that I've wasted time prepping it for paint and assembly to the (someday in the near future) new engine. I also realized that I can be less than observant too- because I disassembled the engine I got from Ray and it never became obvious when I removed the valve covers that one was a little different from the one I removed from my original engine.
Howard, you may have the correct one! I dont think anyone knows for sure as there appears to be many types. The only reason why I think yours is from a G series is because I pulled that same assembly from a 47 G series. But that could have not been original either or carried into the H series. The important thing is that you have the piece with the oil pan bracket to stabilize it!
Jolly Roger, your heat riser looks good! I have mine working well now too. I cant say that I notice any difference in warm up time, but it is easier to start now after a long run, long run defined as like 30 minutes. There is a good thread on here about the correct position of the accelerator return spring and the mysterious hole in the floorpan. I have a couple of spare pins for that hole if anyone is looking for an original. I ordered 1 from green sales and they sent 10 I think. Its really just a simple short cotter pin, maybe a little flatter than normal.
Thanks Jonathan
Thanks Jonathan
The 51 in the top picture I'm pretty sure parked itself in the field while running, when 2 cylinders seized and the block broke inside from overheating. It wasn't pretty. The 52 may have ran when parked, but it appeared to have been parked in the 60's, so there's no real telling the story on that one. The truck was used up pretty hard everywhere else. The ridges in the brake drums were about 4 feet deep.
bhalemail
07-25-2018 08:22 PM
firstrider
04-23-2018 09:15 PM
InfantryCPT
08-22-2016 06:52 PM
mh48
08-11-2009 10:22 PM
