Here's the scenario: 2000 5.4 Triton 2WD extended cab automatic with 160,000 miles died in my driveway. Checked the fuses/relays, no issue. Listened for the pump running with the key on. Nothing. Checked fuel pressure, zero. Fast forward to the bed is now off the truck and I am looking at a fuel pump in a plastic fuel tank mounted mid-ships. Top section came off, no problem. Instead of the one-piece style I was expecting based on the unit I bought at the parts house, I'm seeing part of the pump (attached to the top section by an electrical plug and two fuel lines) on the bottom of the fuel tank. No fasteners are visible on either the outside of the tank or the inside and this piece will. not. move. I've tried turning both directions, pulling straight up, prying with a tool, rocking side-to-side, etc., etc..... I'm out of answers and ideas so I'm hoping someone on the forum will have encountered this type of pump and has the key. If I've left out needed information, just let me know.
So to clarify is it the lines you are having trouble with or removing the pump from the tank? I have a 2007 f150 with 5.4 and mine just had the plastic ring i hammered loose with a flat blade screwdriver.
Plastic ring came off with no problem. Issue is with the "lower half" of the fuel pump, inside the tank and somehow attached to the bottom of the fuel tank. Ford dealer says to turn it counter clockwise 1/4 turn to release 3 tabs but that ain't happenin'.
Can't say i've ever heard of the fuel pump being attached to the bottom of the tank. Maybe the floater for the tank level is caught up inside the tank? My truck had a hose inside the tank attached to the fuel pump (not quite sure what for) that i had to disconnect. Perhaps punching a hole in the top of the plastic fuel pump so you could pry it counter clockwise might work since you plan to replace the pump anyways? Usually just a flat blade screwdriver between the lip and where the pump sits breaks it free.
Problem solved. The pump isn't attached to the bottom of the tank but a cylinder that the pump sits in IS attached. The trick is two tabs, directly opposite each other, on the outside diameter of and sticking slightly above the pump body. If those two tabs are squeezed towards one another, it releases the tabs from the cylinder that is epoxied to the bottom of the tank and the pump lifts straight up and out. Finally! Hope this info helps someone else trying to change out one of these pumps. I was about to give up and have it towed to the dealer.
Well glad you got it out. Be glad you don't have a 2007 like me. I had to take a sawzall to the fuel lines as they are stated non-serviceable by the dealer. Some fuel injection hose and repair connectors and I now have serviceable lines . Dealer can take the 1200$ they wanted for their stupid nylon lines and stick it somewhere.
