Switching to a Holley 1848 465cfm. - Page 11 - Ford Truck Enthusiasts Forums
Old 02-26-2016, 10:35 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Originally Posted by BaronVonAutomatc View Post
Back in the day it was rumored painting the intake manifold on a SBC black was good for 20 HP.
Fine if it's tuned well and better with a manual transmission than automatic.
Yeah, I never figured it would amount to much more than just helping me prevent against vapor lock. =P
Oh, that new carb is pretty and all, but Edelbrock FTW.
The other that interested me is the Street Demon, which is based heavily on the Edelbrock design. I talked my brother into trying one on his 351w and he loves it. Unfortunately, the smallest they make is a 625cfm and I didn't feel like going with a big carb again.
Demon Fuel Systems -1901BK -625 Street Demon® - Shadow Black Ceramic Coated Finish w/ Black Composite Fuel Bowl
Originally Posted by fordboy300 View Post
I must've missed this. I actually drove it normally yesterday for the first time. I like that it has a second metering block I dont know what its for but I like it since the throttle cable is finally opening my carb all the way now. It was actually the first time I took it out since I had it adjusted.
Yeah, I had a secondary metering block on my 465 and liked it. Interestingly, the QF carb has jets in the metering plate, so even though it doesn't have the whole block, you can still adjust it. I wonder what difference it makes going with one over the other.
Originally Posted by Mtphammer View Post
Mine is shiny
That does look great. I remember reading you got one and it sounds like that's really working well.
Originally Posted by Skip1970 View Post
any coating on a metal surface would slow the cooling of it, im pretty sure thats a lie they are telling but it looks great anyhow.
Quick Fuel Black Diamond Series - Quick Fuel Technology
Their nomenclature simply says it's a protective coating and "good looks" . Blocks oil, grease, fuel, grime, etc. and acts as a mild heat barrier. 6% isn't a very big claim, so I imagine there's some validity to it. Dunno. If it helps, it helps. Also, I agree, looks pretty good.
  #152
Old 02-26-2016, 04:01 PM
fordman75
fordman75 is offline
fordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to all
I always thought a black paint/coating would absorb more heat. I was always told dark colors absorb heat and light colors reflect more heat. Whether it does or doesn't block heat, the black does look good! I'm going to paint my Autolite 2100's black. If I can find a paint that won't be effected by the gas & heat.
Now that you've tried most of the 4V carbs. When are you going to start trying some multi-carb set ups???
  #153
Old 02-26-2016, 04:10 PM
AbandonedBronco
I believe that is only the case when it comes to heat sources from light (such as the sun) since light colors reflect light away, whereas dark colors do not. When it's under the hood, it's irrelevant.
Lol, I think that'd be really really fun to try. But if I ever went with something else, I think my next foray would be fuel injection with a MegaSquirt controller.
  #154
Old 02-26-2016, 04:36 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
The fuel injection looks stupid with all them wires though no matter the color
  #155
Old 02-27-2016, 01:45 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
I think we need to add one bit of info that AbandonedBronco omitted: He was dealing with a used carb, and any used carb might have orifices enlarged (drilled), or any number of non original mods that are not known but to a carb guru.
I have a new 1848 and love it, with zero problems, and run 57 primary jets with 67 secondary ones, and my engine loves it. I wanted to pass that along to all those who might read this thread and get the wrong idea about an 1848.
  #156
Old 02-27-2016, 09:33 AM
AbandonedBronco
Oh absolutely. I tried to reiterate that earlier. I think the carb is fantastic and a near perfect fit for the engine. I loved mine. I just started having some problems specific to my particular carb and didn't feel like dealing with them, so used it as a good excuse to get the one I wanted. A Holley 465 should'a, would'a, could'a come stock on the 300.
  #157
Old 05-10-2016, 03:01 PM
xsn10s
xsn10s is offline
xsn10s is starting off with a positive reputation.
I can't wait to get a set up like this or close to it!
  #158
Old 01-11-2018, 04:34 PM
mwm4.2tdi
mwm4.2tdi is offline
mwm4.2tdi is starting off with a positive reputation.
300 6
so what else done to motor,apparently these go good with flat tops & small cam,2bbl.these are an excellent engine,better than v8.
AbandonedBronco
704
01-31-2018 10:10 AM
Raleigh1
1966 - 1977 Early Broncos
10-06-2017 03:16 PM
Big_Rob
1978 - 1996 Big Bronco
07-18-2016 01:26 PM
AbandonedBronco
05-15-2016 12:04 PM
Area351
214
05-11-2016 03:07 AM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
