08 6.4 that seemed to have lost power while driving
Yes, the yellow lever. If nothing comes out then it is al gunked up and will have to be cleaning.
There is a kit that contains a gasket. You would remove the three bolts from the side and then clean it out. sometimes you can stick a pipe cleaner in the yellow handle and get it to flow as well.
Is this correct?
I don't know what to say. Intermittent problems are tough to figure. How do you fix it if it ain't broke? Or in your case, the problem is gone for now?
Last summer, I was in my 99 going down a hill, and the motor shut off. It's a 6 speed so the motor kept turning over. I floored it while at the same time moving over to the shoulder. It got down to 30mph then it took off like nothing was wrong. No codes, nothing. It never happened again.
#28
#29
#30
My truck did the same thing as you're describing. Turn your key on with engine off and get down by the water drain and listen to the electric fuel pump. Mine was pretty noisy. Replaced pump and good to go. You can replaced just the pump or the whole horizontal fuel conditioning module.
It's going to the dealer tomorrow for filters.
Let's see how it works after that.
