Is a rusty centurion worth fixing or stick to Supercabs.
Old 01-24-2015, 03:02 PM
IHguy's Avatar
IHguy
IHguy is offline
Looking for some advice, bear with me. I currently have 2 F150 Supercab Shortbeds. 1984 Rustfree Arizona XL 302-2bbl/AOD/3.55/2wd with crappy/ugly colors (bright copper glow/white) paint and crappy tan interior that i accidently bought off of ebay. Second truck is my old faithful 1994 XLT 5.8/e4od/3.55/4x4offroad with so-so gray interior. Rust has done in the 94 body and frame (I live in Illinois). Now i found a bright red 1996 F150 Centurion crew cab shortbed 5.8maf/e4od/4x4. it has a few minor mechanical issues, and plenty of rust. The frame isnt quite as bad as my 94 but still has some of the delaminating on spring mounts, etc. So, do I use the 94 as a drivetrain donor to the 84 and still have to paint it and find a nice interior? Or buy the centurion and either do minor repairs on it and drive it, or try to restore it? I like the look of the Supercabs better but a crewcab would definitely be more functional. Any advice would be appreciated.
Old 01-24-2015, 03:09 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
I am a sucker for F150 Centurion crew cabs. Their quality control sucked but that is nothing a little TLC could not overcome. My vote is for building the Centurion F150 conversion.
Old 01-24-2015, 03:14 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I say build your own.
The centurion is such a BUTCHER job. They welded a crewcab rear to a reg cab front. How F'n stupid is that?!?!? Just put a REAL FORD crewcab on and be done
Old 01-24-2015, 06:11 PM
Sdowdle541's Avatar
Sdowdle541
Sdowdle541 is offline
If the frame is good would it be worth it to buy a factory crew cab and throw on the centurion frame? Something about f-150 crew cabs is just cool to me!
Old 01-24-2015, 06:58 PM
Diesel_Brad
the frame is butchered too.
If I was you I would look for a F250 crewcab short bed
Old 01-24-2015, 08:29 PM
Snipeston's Avatar
Snipeston
Snipeston is offline
I have a rusty F150 Centurion and have a rust-free cab from a F350 I pulled at a pick n pull for $250...swap coming this spring/summer...Project Recab!!!
Old 01-24-2015, 09:32 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
If you want to stick with a 1/2 ton, and don't mind doing some rust repair/prevention, and you want a crew cab, go with the Centurion. I have one, I've put extensive work into it, and I still have extensive work to do.
While there's a lot of things I would have done differently if I were making a CC F150, they're not a complete hack job.
What Centurion did to make it a CC: Started as a regular cab short bed. They cut the cab in half, then grafted in CC roof and floor panels, and welded in the B pillar. Cut the frame at the straight part under the cab, and extended it with channel, along with a fishplated channel on the inside of the frame. That part of it is actually very stout.
As far as fit and finish, they did a decent job. Once I got my interior stripped out, I noticed that they used crimp connectors to extend wiring harnesses on the inside. I cut those out, and soldered/shrink wrapped the way it should have been done.
The roof and floor panels weren't prepped correctly after welding, so I went in and spot blasted the corrosion, then used a zinc primer top coated with coal tar epoxy to protect the welded areas. So far, after 4 New England winters, that's holding up pretty well. Nothing was rotted through, it was mostly surface rust.
I scored mine for a super price, so I didn't mind putting some sweat equity into it. And I don't mind the sweat equity I'm about to put into the body and drivetrain. Very soon, I'll be starting on an 05-up Super Duty axle swap. For me, it makes sense, because I bought the truck so cheap. In my neck of the woods, a decent but still rotted F250 CCSB would sell for at least $5k, more if it's a diesel, even more if it's a southern rust free truck. Neither of which I'm willing to pay for a 20 year old truck.
As for your situation, it all depends on what you're looking for, how much work you're willing to put in, condition of the Centurion, and selling price of the Centurion.
Old 01-25-2015, 08:22 AM
IHguy's Avatar
IHguy
IHguy is offline
Thanks for the replies, now i have another dilema...
I want a crew cab, but I totally agree with Bob about the f250 CC/SB trucks. Now my new dilemma is I found a second centurion for sale. this one is a 1995 Electric Current Red 4x4. From the pics i have, it appears to have less rust (sills and frame look much better). My new dilemma is that i can get the 96 bright red truck for $1300 and the 95 current red truck for $1500. I would really like to have the 96 for the maf because i am a gear head and plan on upgrading the engine, but the 95 is less body work and a little more money. Thoughts?
Old 01-25-2015, 08:48 AM
Diesel_Brad
Buy a 2wd CCSB and make it 4wd. it is all a bolt in procedure
Old 01-25-2015, 10:11 AM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
Hahaha I see what you did there!
Old 01-25-2015, 12:31 PM
Diesel_Brad
No. No you didn't. No way did I say to buy anyone certain truck. I am SURE his budget is well below 25k
Old 01-25-2015, 02:54 PM
Bob Gervais
Buy the less rusty one. Unless you're planning on throwing a huge cam or forced induction, the MAF won't give you that much of an advantage. Plus, the MAF can be swapped in the 95 pretty easily. Rust is a pain in the ***.
Option two: look outside of salt states for a way less rusty truck.
Neal 97 250
WTB - Ford Trucks & other vehicles
01-25-2012 05:07 PM
robjs111
1997 - 2003 F150
11-19-2011 09:18 PM
kc5gxl
06-17-2007 07:14 PM
lostin90s
Pennsylvania Chapter
02-28-2007 07:27 AM
RockinWagin
06-16-2003 11:59 PM
Quick Reply: Is a rusty centurion worth fixing or stick to Supercabs.
