1982 F250 300 Straight 6 Stray Vacuum Hose
I have an 82 F2 with the 300 straight six. The truck runs pretty good when driving but it almost dies when it idles. I was looking around and found a stray vacuum hose. It appears to becoming off of a connector with three other hoses that screws into the intake manifold. I had trouble locating it on the Vacuum diagram. At idle there is vacuum in the line and when I cover it with my finger the idle gets worse and almost dies. I'll post a picture so you guys can get more of an idea what I'm talking about.
Okay, that hose supplies vacuum to the temperature sensor located in the air cleaner housing. When the engine is cold, the sensor allows vacuum to be pulled through the second vacuum hose [two hoses attached to the sensor] to a servo motor located on the intake snorkel [where air enters the air cleaner]. This servo motor moves a door [flap] which then draws warm air from the exhaust manifold area. When the engine is warm, the temperature sensor blocks the vacuum and the door opens such that cool air enters the air cleaner through the rectangular flexible hose connecting the snorkel with the radiator support near the battery. In actual practice, this system moderates between cold and hot to maintain a desired temperature [~105F] inside the air cleaner. This prevents icing of the carburetor on cool damp mornings.
With the hose being loose [as shown] and open, there is a definite vacuum leak. This will be noticed most at idle and low speeds.
If this situation [loose hose shown in photos] is not recent, I suspect someone has adjusted the idle air/fuel mixture screw [at the base of the carburetor] to compensate for the vacuum leak caused by the vacuum hose being disconnected. Reconnect the hose or at least, plug it [a golf tee works well] and with the engine at operating temperature, adjust the idle air/fuel screw to the smoothest idle.
LARIAT 85
05-24-2007 07:59 PM
hu5ker555
01-25-2005 09:12 AM
