Recall 2011-2014 F250-F550 6.7L 14E03
Old 09-05-2015, 09:11 AM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
just looked at the one replaced because of the EGT12 under warranty:
ac3z-5j213-c
So it must be something different.
Outside appearances look the same as the others.
  #632
Old 09-06-2015, 10:35 PM
rtazz17's Avatar
rtazz17
rtazz17 is offline
Originally Posted by Thom12
Mine is doing the same thing.
Mine is the same as it was prior to recall.Same def usage.Same regen frequency.Been 4 months since I had it done.
  #633
Old 09-08-2015, 07:25 PM
badgeking's Avatar
badgeking
badgeking is offline
first time ever posting to one of these forums. but after reading all the info about peoples problems with there 2015 I need to find some help. bought a new 2015 f350 platinum back in September 0f 14 took the truck in around 9000 miles told dealer the check engine light came on and went into limp mode code was p207f had to borrow code reader at auto zone 250 miles from home to read and clear code. dealer called said they could not find any codes (ya I had to clear them to get home)
then around 15000 miles truck started running really bad went into limp mode only 5 miles from dealer took it in. they did a reflash on the pcm. picked up the truck then had to do long run to salt lake city and back 4000 miles round trip. fuel mileage was only 11.3 and went trough 4 2.5 gallon cans of DEF. got home driving around town for a week fuel mileage down to 10.3 and Monday dam CEL again took it to dealer they had to replace NOX sensor. I have less than 25000 miles on truck and its been in the shop 3 times already I see all these TSB that ford now has out along with all these stories out on the WWW about these 2015 and regen issues. is this truck realy this bad? I travel coast to coast and need to have reliable transportation can't afford to be stuck on the road some were. and with less than 12k left on warranty what happens after that? any info anyone can chime in with would be great.
  #634
Old 09-09-2015, 08:18 AM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
I'm not sure what to say about your issues except that it is unfortunate. You do have 100k miles warranty on the engine though. 3/36 is just the bumper to bumper. Many of us have purchased extended warranties to supplement, because no matter who's modern Diesel you buy, it gets expensive to fix when you see how many electronics are involved.
bnmccoy
6.4L Power Stroke Diesel
06-23-2011 11:56 AM
frt2599
6.7L Power Stroke Diesel
126
04-28-2011 12:58 PM
fordpride
Escape & Escape Hybrid
04-25-2010 08:26 AM
Serg450
17
08-28-2008 01:04 PM
ELO168
2004 - 2008 F150
31
05-12-2005 09:52 PM
Quick Reply: Recall 2011-2014 F250-F550 6.7L 14E03
