ID this FE/FT
That intake was cast in 1967.
Trying to ID one of these engines via visuals is just about impossible. Measuring the stroke will narrow it down to either a 390 or a 352/360. The FT has a larger crank snout than the FE and a cast iron timing cover with a mount incorporated into it, although early FEs (still with smaller crank snout) also used this mounting setup.
More info and measurements are needed if you want us to ID that engine.
TicketMan4u
20
03-20-2012 08:47 PM
96ExtracabPSD
11-11-2004 04:27 PM
390fourby
09-05-2004 12:31 AM
Spudco
17
02-12-2003 06:23 PM
