Shifting hop
Old 01-12-2015, 03:01 PM
1stpowerstroke's Avatar
1stpowerstroke
1stpowerstroke is offline
Shifting hop
This weekend I purchased my first diesel. It's a 2005 F250 6.0 with about 152,000 miles on it. Here are the mods on the truck. EGR delete, ARP head studs and new head gasket, 190cc injectors, AirDog II, Billit River City Diesel torque converter, billit input shaft, Suncoast rebuild kit with transgo shift kit and a SCT livewire tuner. My question is when I accelerate fairly hard, it shifts extremely hard and almost like it misses then catches. It is an automatic. The tuner was put on before any of these mods were done, so is it possible if I get a new tuner or at least updated tunes, is it something that a tuner could possibly work out or am I looking at another issue?
Old 01-12-2015, 03:06 PM
PowerLines's Avatar
PowerLines
PowerLines is offline
I'll be following along. Having the same hard shift with mine (also sct tuner)
Old 01-12-2015, 06:26 PM
78fordman's Avatar
78fordman
78fordman is offline
Do you have any codes set? There should be a custom tune on there for those injectors see which one it is. Also can you set the tuner to defuel on shifts?
Old 01-13-2015, 07:41 AM
1stpowerstroke
I am not familiar enough with the tuner to know if there is a preset tune to work with the injectors. The programmer has an extreme race, extreme street and tow tune on it. It is on extreme street right now. All of these custom tunes were loaded before the injectors or pretty much anything else was done. I talked to Innovative Diesel this morning and the guy I talked with acted like it was probably solenoids and nothing a tune would change. Anyone else have anything like this? Any idea what the average cost is to replace the solenoids?
Old 01-13-2015, 07:43 AM
78fordman's Avatar
78fordman
A stuck solenoid would cause a code to be set. Check for codes even if you do not have a check engine light.
Lee44054
1999 to 2016 Super Duty
05-15-2015 09:32 AM
URDADDY
6.4L Power Stroke Diesel
27
08-19-2014 06:24 PM
Nic High
10-31-2013 05:44 PM
GeneLaw1
02-12-2013 09:06 PM
40searay
01-30-2008 07:21 AM
Quick Reply: Shifting hop
