79 F250 Cummins - Build Thread
Old 11-27-2017, 09:43 AM
650's Avatar
650
650 is offline
Looking great. Subscribing to see more.
  #77
Old 01-24-2018, 08:19 PM
tabascom16's Avatar
tabascom16
tabascom16 is offline
The winter time blues has struck. Not much progress of late. Got in the mood to work on it some the past few days. I figure it is time to figure out some plumbing in the engine bay. The Aurora 3000/5000 twins are going to be tight to the inner fender so may need some mods. The exhaust is inevitably going to need a hump in the passenger side floor. There just isn’t enough room for a 4” downpipe coming off the bottom turbo that is already further back than the stock turbo.
Not sure what what to do about coolant lines since I am going to go back to a Ford radiator to keep things “clean” looking. I remember some aftermarket place selling coolant lines. Anyone have any experience here?
Forgot to attach picture and wouldn't let me add it in editing so had to post below.
  #78
Old 01-24-2018, 08:28 PM
tabascom16's Avatar
tabascom16
  #79
Old 02-06-2018, 07:47 AM
Dairydiesel's Avatar
Dairydiesel
Dairydiesel is offline
1977 Ford 150 cummins/ power brakes
Hey , nice build, doing the same on a 150. Just wondering about the power brakes? Where did u get the vacuum from??
thx jamie
  #80
Old 02-06-2018, 10:17 PM
tabascom16's Avatar
tabascom16
These era dodge Cummins motors had vacuum pumps in front of the power steering pump. I plan to go with hydroboost though.
thx jamie
  #81
Old 02-07-2018, 07:57 AM
Dairydiesel
Hey nice mounts!!! Was wondering if u could give me some dimensions, like how far are the rubber mounts from the frame on each side? Is the motor centred or off set?
thx jamie
  #82
Old 02-07-2018, 08:00 AM
Dairydiesel
Oh if that's what that little fitting is for befor the steering pump, wasn't sure what it was for, also what kind of air to air you gunna use
  #83
Old 02-07-2018, 08:04 PM
tabascom16's Avatar
tabascom16
Not 100% sure what you are referencing when you mentioned the air part. I assume you mean intercooler. I have already been working the 99-03 intercooler previously. It does fit nicely.
I put the passenger side mount with only about 1/8" gap between it and the frame rail. Even the original engine in these was off to the passenger side. I then used my stock motor mounts and cut them off flush at the frame rail. I used the 2nd gen Cummins mounts that came with the Dodge truck. I used 1/8" plate steel to make the mount as well as the gussets. Not much measurements at the time. I just got the engine where I was pleased, roughed out some brackets, tacked them in place, removed and welded up with gussets. Depends on what measurements you are wanting I could cough some stuff up for you.
  #84
Old 02-08-2018, 12:30 AM
burnthelight88's Avatar
burnthelight88
burnthelight88 is offline
Wish I lived closer to somerset, I'd love to see this build in person!
  #85
Old 02-10-2018, 07:41 AM
Dairydiesel
Ya I was talking about the intercooler, herd that ones from a 6l diesel work good to. I made my mounts yesterday and did the same as u said, just placed the engine where it fit good and made sure that the trans had lots of room all around it. What kind of trans are u using, I'm using the 47re with a full manual valve body and a rachet shifter.
  #86
Old 02-11-2018, 02:03 PM
Dairydiesel
Motor mounts
  #87
Old 05-27-2018, 03:46 PM
tabascom16's Avatar
tabascom16
Well I did not get motivated much this winter. I mostly worked on building an electric guitar as something else to do. Now that warm weather is here time for some truck work. Going with a 4” stainless exhaust with a resonator to reduce the drone in the cab. Using a 3rd gen down pipe with a 3.75” flange and about an inch cut off the front end. Next will be to get the cab roughly in place and see if I just hammer and dolly the floor out of the way or if I will need more drastic measures. There just is not room for 4” exhaust and other way.
  #88
Old 09-23-2020, 07:23 PM
tabascom16's Avatar
tabascom16
After a long and slow effort with body work, panel replacement, and rust repair over the past two summers, finally some color. Sorry the two tone picture is dark. the dark blue is not anywhere near that dark, but it was close to the sun setting. I at least try and do good body work. I like the challenge of painting, but I never expect it to be show quality. Both blues are metallic. Painting season is just about done here in the mountains of PA. Getting too cold to paint.
The winter will be time to sand and buff back the clear, de-anodize and polish the trim, figure out the wire harness and some things like a hydro-boost setup. The Cummins is at a friends shop getting a refresh. With the compound turbos he said a good target is 600 rear wheel horsepower.
To recap bigger aspects of the build:
-Regular cab F250
-Front Dana 60
-Factory disk 14bolt in the rear
-Currently sitting on 37s but might go down to 35s
-95 12V Cummins and NV4500/NP241 drivetrain
-Aurora 3000/5000 compound turbo setup
  #89
Old 09-23-2020, 08:58 PM
Lrrr-RulerOfOmicronP's Avatar
Lrrr-RulerOfOmicronP is offline
The two tone looks great!
  #90
Old 10-12-2020, 08:29 AM
my79f's Avatar
my79f
my79f is offline
Any good updated paint pictures?
Quick Reply: 79 F250 Cummins - Build Thread
