Coolant: Ford "specialty" orange....Dexcool?
#32
Check the lower radiator hoses where there are O-rings connecting the hoses to the T-joint, they leak and usually on cool down. Pressure testing on my 5.0 didn't show the leaks, I laid down under truck after it ran a while and found the leaks, helps to have a clean engine compartment to start. Also the hose from the reserve bottle is a common leak point, usually the O-ring or the clip has gone bad that holds the hose to the tank.
Supercab
11-15-2010 02:23 PM
