5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
Issue with mating Coyote to 4R70W
Old 01-04-2015, 09:08 PM
aaronbauer's Avatar
aaronbauer
aaronbauer is offline
I had my local speed shop build me a 4R70W transmission to go with my Coyote crate motor. I am putting this all in a 1951 Mercury M1 Resto-mod.
I ordered a block plate from Performance Automatic, it fits the engine perfectly, but putting it up against the transmission I see some major issues...the location of the starter and the lower two holes are way off? There's no way this will work...
Since I can't post pictures, I uploaded them to Shutterfly
https://aaronbauer.shutterfly.com/
I thought this should be simple, but unfortunately is not.
Looks to me like they need to find the right trans case. Argh...
Curious what engine this transmission fits and what trans case I need that does fit?
Old 01-04-2015, 09:24 PM
aaronbauer's Avatar
aaronbauer
Did some research and am answering my own question...lol
4R70W comes in two versions small block and modular. This trans case has to be for a small block. Back it goes...
Old 01-19-2015, 10:47 AM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
I'm very interested in how this swap goes for you. How are you going to run the transmission? a stand alone computer? Have you started a build thread?
Old 01-20-2015, 05:34 PM
aaronbauer's Avatar
aaronbauer
Why Ford didn't integrate the ability to run an auto trans into their Coyote wiring harness is a mystery to me, so yes no choice but to run a stand alone trans controller. I have the compu-shift II. Not cheap, but are supposedly one of the better controllers out there.
Build Thread...
I haven't made one yet, but have planned and promised to. It is definitely on the to do list. I am finally at a point where I could start using some input from the FTE group. Hopefully will have it in the 1948 - 1956 F1, F100 & Larger F-Series Trucks thread soon, so keep watching...
Old 01-20-2015, 06:01 PM
craftsmangary
Yes I also wish the Ford Control Pack would support their automatic transmissions, but none of them do. With the way everything is integrated in these wiring harnesses it would be a PITA to diet down a harness, then you have to deal with the PATS and the fuel pump driver module. Please keep us posted on your progress.
Old 02-14-2015, 07:30 AM
craftsmangary
Any progress?
Old 02-16-2015, 09:56 PM
47FordEd's Avatar
47FordEd
47FordEd is offline
Trailering
4R70W
Check out Street Rodder, June 2014. Covers this motor and trans.
Old 03-02-2015, 03:03 PM
aaronbauer's Avatar
aaronbauer
Just started the thread on the weekend
https://www.ford-trucks.com/forums/1...-restomod.html
thundersnow70
05-30-2018 09:53 PM
Nick_P
16
07-03-2017 03:47 PM
bobs 80 f250
12-17-2015 09:20 AM
midcal48
02-12-2011 10:43 PM
jmadsen
09-13-2008 12:24 AM
Quick Reply: Issue with mating Coyote to 4R70W
