"Belle" 1952 F-1 build thread.
#211
#212
Here is the thread about blades.
https://www.ford-trucks.com/forums/1...e-problem.html
#213
Thanks for the compliments. It's nice being able to just enjoy driving Belle but I am missing the fun of doing projects. Friend just bought a 60 El Camino so maybe that will provide some distraction for awhile. Sure cheaper working on his than mine.
#214
#215
Thanks to Ross' help I used Trico part number 51-062 arms available from O'Reilly auto. I could have used Trico blade 33-101 but chose to go with a marine blade instead. Sorry I don't have a part number right now as I didn't go to work today (20" of fresh snow, can wait till tomorrow).
#216
Trico blade TRICO Classic 33-101 - Wiper Blade | O'Reilly Auto Parts
Marine blade 11.5" Deluxe Stainless Steel Curved Wiper Blade | Marinco
#217
The Marinco look more like the original wipers.
#218
It is a marine blade also made by AFI. The arms from Trico put about twice the pressure on the blade as the arms that were on the truck. My reason for using the Marinco/AFI blades was as you said, they look more like the originals. It's also nice they wipe more of the windshield.
#219
#221
That block is a combination valve. It does several functions, acts a a proportioning valve to limit rear pressure to prevent rear lockup. It acts as a hold off valve so pressure starts going to the rear drums before the front discs and it provides the pressure check valve function. Nice because everything is in one valve. At the time I installed mine they were having production problems and it took three before I got one that would work. The others I have installed work fine. You don't have to use one but depending on your install will need other valves to give you the functions of this valve.
#222
The Marinco arm has a silver plastic cover over the mounting end of the arm that is kind of ugly. The Trico is polished stainless, just like the look of the Trico better.
#223
#224
Rimrock F1
I read through the whole thread and caught that you said your tire size was 255 60R16 and included a pic of the rear fender just after it went on... but also I remember you said the front tires were smaller but I can't find what their size was? I like the stance on your truck and I 'm trying to pick tire/wheel/wheel back spacing/rear axle flange to axle flange measurement now on my 51 and I am wondering if you would be so kind as to list what your tire/wheel/wheel b.s. is and any rear end width data you may have?
After doing some searches it seems there are always several members dealing with this very conundrum at the same time and after seeing how nice your truck came out it probably help more than a few of us from ordering wrong tire/wheel combos/rear end combos. Thanks for your time.
#225
