Gauge pod parts?????
Originally posted by ryanben
You drill into the pipe that goes from the exhaust manifold to the turbo. There are two different pipes that bolt together. You want to drill into the pipe that is closest to the exhaust manifold. It should have a little bit of rust on the outside. At least mine did anyway. The other pipe that runs up to the turbo is gray and shiney. Hope this helps
