2011 f-550 with 6.7
2011 f-550 with 6.7
Hi all, I have a 2011 550 with a 6.7 which has developed an electrical issue.
Driving on highway with no warning the dash light started to go on and off then the fan, which was off, went on and off at high speed. no motor issues,i.e. stalling. Battery light came on and check brake system in message center.
Checked and replaced both batteries ( one was dead ). Acc Bat was dead.
Found code P0625/ generator field /f terminal circuit low. tested primary alt. and its ok. Battery light still on. Going to test 2nd alt.
Anybody run across any of this ,truck has 30k
Thanks
Thanks
I don't recall reading anything with all your issues but it does sound like you've eliminated the easy stuff.
You have fresh batts and both alts work properly?
Check the voltage regulator if there is one....
Also, there is the possibility of a chaffed wire somewhere causing issues like this. There are a couple of folks here that have had experience fixing this. I believe it's under the main power dist box somewhere.
gary85314
17
03-14-2010 11:40 AM
