To cab light or not
I have mulled over this one. I would bet those with leaks didn't do the due (diligence), and probably used household sealants. Transportation sealants face different problems - like vibration and sustained winds. I suspect if you get real about it, you can prevent leaks.
Here's the question: Are you looking to have those yellow VW bugs adorn the brow of your truck, or are you looking more for the night effect of the lights? I ask this because amber LEDs would be smaller (easier to seal), lower power, and would be more noticeable at night than during the day.
I installed the Recon amber led cab lights from Clay 3 years ago. Bedded the light bases with Sikaflex-291, a sealant widely used in the Marine industry that has the ability to expand and contract with changing temps. Set each light base in liberal amounts of sealant. When you tighten the base bolts get 100% squeeze out. It cleans up nicely with alcohol. We get plenty of rain up in this corner of the country and mine have not leaked so far.
Tom-2003 F350 4x4 Lariat
I like the look of them. Stock roof lights are just right - not too flashy, not "16 year old kid with an AZ gift card" look. But, would I invest the time and money to retrofit??? Probably not.
The PO of my truck DIY'd some roof lights that don't belong on the SD. They look more like OBS lights, and I dislike them. But I'm stuck with them - and stuck with the problems they bring. They don't leak (yet), but they use an odd ball bulb and one of them keeps losing power. *The joys of a pre-owned truck....
If you want the cab lights I wouldn't worry about leaks too much just use silicone and plenty of it when you install the lights you won't have any leaks. My truck came with no cab lights and I installed 9 across the top and that was back in about '06 and I have not had one single leak. They are Recon lights which are LED. I didn't use any fancy silicone either just the stuff you get at the hardware store. You could always use a silicone gasket maker type stuff if you wanted a little extra insurance. The big thing is make sure it sits in where it is warm and is good and dry before you take it out. I did mine in the winter and left it in the heated shop for a couple days to make sure everything was good and dry before I took it out for a drive.
I've found that plastics and metal are fairly forgiving for removal. Some types of wood can be a real bear though. Try some 3M 5200 if you want a sealant that's tough to remove from any material.
This is just something to consider when using a good sealant like 3M 5200. One other thing to think about - it's freaking on there now, buddy. Changing something out that's been sealed with this is almost as much fun as removing JB Weld.
As a boater, I always have a tube of this stuff on hand. Reading the instructions, it says to set your stuff in place with the screws a little loose, then let the sealant dry. Once the sealant is set, tighten the screws. That may work with a through-bolt on fiberglass, but screwing into sheet metal may have you tightening everything with wet sealant. This would bind the sealant to the sheet metal screw thread for a better seal there.
A little OT but your right Rich. If you set items in wet sealant and you have pre-drilled for bolts or screws, the fasteners tend to pull the sealant through for a good seal. Like I mentioned any excess squeeze out cleans up with alcohol. 5200, whoa baby! you better like where you put it.
taylornelms
09-27-2010 12:27 PM
TexasGuy001
36
11-09-2007 01:12 PM
