The best year for the EFI 460
#31
bingo.
i wasn't saying he should go for aftermarket heads, I suggested it as a starting point because theyre relatively cheap and the available head options are much more abundant. it was a suggestion as a possibility, not a recommendation, so he can decide whats best for him to suit his needs. cant decide whats best if you aren't aware of all the options...
absolutely would be easiest to run an aftermarket efi setup that bolts right up, or even TBI off of a 454 or the like. but that stuff gets pricey very fast, and the TBI conversion would require more work and time than using adapters to accommodate the fueling setup already in the 460's. the idea of adapting is to utilize the efi parts one would already have in their possession, keeping price and time invested to a minimum.
#32
Yep, that's pretty much what I have in mind.
He mentioned a couple of things I'm not convinced of.
180* thermostat. I thought EFI engines liked 195*?
Larger intake valves with stock exhaust valves. Wouldn't that be kind of counter-productive?
Piggyback chip for the ECM. He must have been thinking of a MAF truck, right?
I asked here; https://www.ford-trucks.com/forums/1...1997-f350.html Why stay with an SD friendly cam?
The response was that it was fine for the projected 420Hp/570Tq of his engine.
You have no pressure (well, 14.7 psi at sea level) pushing the intake charge.
The piston is *forcing* the exhaust out.
If you put big valves on both sides in that head, they like to crack between, and from the exhaust to the plug hole too.
#33
Ahhhh yea I missed that. Would be easy, so long as the eddy piece (or tb) has a provision for iac
#34
I *think* the idea is to run the heads cooler (in order to stave off detonation) and change the temperature sensor output to fool the computer into thinking it is at operating temperature so it gets out of cold start mode.
And while it's true that the piston forces the exhaust out, it also sucks the intake in. So that's flawed logic thinking you need a bigger intake to help the air in.
As for the thermostat, 195 is there for emissions reasons. 180 will keep the engine out of cold start mode while adding a little pep because cold air is more dense. A 160 degree t-stat will keep it in cold start mode if that's what you're looking for. Fuel economy will go down the drain though.
#35
#36
Years of experimentation has shown that an exhaust flow of approximately 75% of intake flow is ideal. If you have a head that flows 55% of intake in the case of the F3 head then why would you want to put a bigger intake in? That's what I'm trying to get to. I don't care that at most you're have 14.7 PSI pushing in, that's enough. If you don't have enough flow to get the air out you won't get enough air in.
Ford heads always seem to be weak on the exhaust side in general.
The mustang TB has a provision for IAC. An 80mm would be about the same as the twin 56mm one that's stock. BBK makes a nice one.
#37
I'm surprised more people aren't running aftermarket heads then. . .doesn't get any easier than the 3849 adapter. even if that adapter didn't exist, it'd still be easy with the carb adapter and probably be about the same price ultimately. I was confused when you said "4 port TB meant for aftermarket EFI".
#38
#39
Not sure what it would take to make something like that work, but after I thought about it more I remembered some of the Mustang guys running modified carb intakes with an elbow to mount a round single TB. If you look I'm sure you can find them with oval and dual port TB's too, but an 80mm is roughly the same as the twin 56mm - actually it's just a touch larger. A 79mm would almost exactly equal the inlet area.
I'll put it on my project list... I should be able to get to it in about 8-10 years...
#40
The problem with the Ford heads is they're so lopsided to the intake to begin with. They need a bigger exhaust valve desperately. Bigger intake; not so much.
As for the thermostat, I thought 195* was a must to keep the computer happy. Now that I lnow better, when the weather warms back up I'll change it back to 180*.
#41
remember, the exhaust is aided by the combustion itself finding the easiest exit - the exhaust valve as its opening, causing its own scavenging effect. this doesn't change the facts that you've already brought to the table; intake/exhaust ratio and how the ford heads don't meet what is ideal....just a side note.
#43
Will enlarging the intake make power? Maybe, but work on the exhaust definitely will.
#44
I understand what you are saying; there are forces getting the exhaust out and forces getting the intake in. For years though it's been known that having the exhaust flow around 75-80% of the intake is a sweet spot for making power. When you're starting with a 55% ratio I can't see the reason behind enlarging the intake and making that ratio worse. The best bang for your buck with most Ford heads is on the exhaust side.
oh I wasn't contesting what you were saying, the standard is to achieve at least 75% of exhaust to intake flow and I recognize(d) that you were saying just that. I was just adding to the discussion, as I cant help myself.
I was just stating the reason the exhaust-intake relationship, even at the acceptable 75% level, works is due to the "help" the exhaust gets. the only reason 2v/cyl heads get smaller exhaust valves/ports is because there isn't enough room to put both at the same size both physically and practically (economically). a lot of 4vpc heads often have the same size valve and a ratio much closer to 1:1. I'd venture to say the reason ford's (and other factory heads for that matter) intake/exhaust ratio is so abysmal is emission requirements, cost, and efficient power simply not being a priority.
i couldn't agree more that the most power to unlock is in the exhaust.
Ben_E
10-22-2015 07:31 PM
harrisford
07-17-2011 12:26 AM
kettle-one
05-05-2009 07:28 PM
wsu0702
17
06-16-2006 10:59 PM
