Has anyone applied cerakote themself
on
on
Actually...
After heavily blasting the exhaust manifolds inside and out... and properly pre-treating them would make excellent substrate for a cerakote bond. The result would be a rust proof surface with favorably enhanced thermal tolerance. Akin to being polished, the inside surfaces coated will provide a less restrictive conduit for hot gasses to pass. The .1-.2mil application thickness might be construed as a surface area reducer, but the thermal improvements coupled with the smoother surface finish more than compensate the loss.
Fellows with ceramic coated up pipes claim better egt's and faster spool times somehow associated with keeping that heat in the pipes. It only stands to reason the more control you can place on that heat near the source... the better.
I will follow your endeavors closely John. To me it seems like a very logical and proactive bit of wizardry.
Never mind the naysayers... keep up the good work!
Could be, and some others. Some are air dry, some heat cure only, but do the same thing. One I used makes coatings for the military, not sure of the brand, but I spray them on with a small touch up gun. Even most air dry types can be heat cured so you can work with the part faster. I could find out from my source if you want. I usually get it in small unmarked cans of 4-8 ounces, but it will be a day or two.
cigarxtc
General Automotive Discussion
04-29-2004 03:26 AM
