My Bump is a Workin' Son Of A Gun!!!
#482
It really does. The brakes are the only short coming. If I really wanted to nit pick, power steering would come in handy backing up.
A couple months ago I was pulling a 18' flatbed lightly loaded with some steel. (4,000lbs maybe)
Anyway, I had to make a pass going up over a bridge. Dropped into 3rd gear and went about 3/4 throttle, it picked up and went from 55-75 in not much time. It's got the power!
Thanks!
#483
i have been driving pick-ups since the mid 60's.. most of the trucks back then were manual(manpower) steering and brakes.. they will work fine as long as you drive looking and planning ahead .. using your gears to slow down before hitting the brakes works well.. keeping the kinpins, tie rod ends, idler arm and drag link greased after checking the gear oil in the steering box makes it easy to steer with the bigger steering wheel most had.. my 71 still has manual steering and drum brakes and so far i lived thru it..
#485
Not that the load was that heavy for the truck, just a bulky truck full of furniture and housewares. Me and the '68 helped my son move to a new apartment in Chicago. The hardest part of the move....lugging heavy couches, chairs, and beds up three flights of narrow stairs in an old apartment building. Truck handled it great. My old body can't handle those heavy loads any more! Every muscle in my body was sore this AM. A little fine tuning on the truck before I left, and she ran great. I am going to need to install A/C in the truck. Even with the heat off, hot water still flows through the heater core, and about blasted me out of the cab. It was HOT!!
#486
David + Don Drive Her Home
#487
Nothing to be impressed about, for sure. I drove mine with 4x manual drums for 4 or 5 years until I had the heart-pounding blood-pumping come-to-Jesus near-miss that convinced me it was time for an upgrade (trailer with 2 yards of topsoil, came around a curve and traffic was backed up at a standstill, it was all I could do to bring it to a stop about a foot away from the car in front of me). Got disc brake setup from a 78 F100, then a hydroboost from a 2004 F450, and m/c from a 79 Lincoln. Now it will stop on a dime and give you change - even when loaded!
#488
#489
on
20 straw bales I hauled recently.
I showed up to load them and the gal says to me in a concerned voice "you didn't bring a trailer?" I just said, "it's ONLY 20 bales..." and then once I had them loaded it was "you're not gonna tie them down?" Nope haha
I had room for more haha
PS: that's my brother's Bronco
#491
Hauled a few loads of brush from the church on Saturday. Very light in weight, but, bulky. Got to the drop off area, went to back up, and the gear selector was no longer attached to the transmission. I knew right away that little C clip that holds the linkage rod in the trans lever had come off. Sure 'nuff. Crawled underneath, put the rod in, and . got it home. While at the brush drop off, a guy says, "Hey, that is too nice of truck to haul brush". I said "Hey, the truck works for me, I don't work for it". Although that isn't really true!
#495
