1995 died while driving and no restart
Merry Christmas all!
Well I have a 1995 f150 with a 5.8 and I was driving it the other night and I was slowing down from a 55 to a 45 and my truck just all of a sudden sputtered and died. I pulled it off of the side of the road and it wouldn't restart. I can't hear my fuel pump kick in but I have power to it and I checked all fuses and checked my fuel pump relay and it's good... I also checked the inertia switch. So im leaning towards the fuel pump (spectre brand) which is only a year old..
And help would be great! Thank you
Something similar happened to me yesterday. I stopped at a feed store and when I went to leave the truck started and ran for few seconds then died suddenly and wouldn't restart. Checked all the fuses and they were good. It turned out to be the MSD coil I put on when I did the tune-up. I had my stock coil in the tool box, replaced it, and it fired right up.
The KOEO test is an electrical test of the circuits hooked to the computer.
The code from the CM tell you what failed during the driving self-test.
DTC 542 KOEO indicates that one of the following has occurred:
No Start:
-- Inertia Fuel Shutoff (IFS) switch not reset or electrically open.
-- Open circuit between the fuel pump and FPM circuit connection to the power-to-pump circuit.
-- Poor fuel pump ground.
-- Fuel pump electrically open.
No Start:
No Start:
No Start:
A fuel pump being electrically open means it's bad?
Also does a open inertia switch mean it's bad or has a bad wire?
Thank you so much subford!
Drivers side radiator support, G100.
It can and most of the time it is. But check the other options first.
No, most of the time it means the inertia switch is tripped and needs to be reset. You reset it by pushing down the red button on top. Some times the inertia switch is bad.
