Can I fill my old home heating oil tank with on-road diesel?
I am almost done converting from an oil furnace to an air source heat pump.
I still have an underground 500 gallon oil tank that is darn near empty. With the recent price drop in diesel, I would LOVE to top that tank off with on-road taxed ULSD. Then when the price goes back up, I'm saving money.
Has anyone done this?
Thanks
-Matt
Thanks
-Matt
We use several old fuel oil barrels for gas but they are above ground tanks and cleaned well, a buried tank will be very hard to remove the last little bit of fuel oil and clean. If your daring you could remove all the old oil you can and fill, then use very good filters but I guarantee it will be dark looking fuel the first few tank fulls.
Received 3,102 Likes
on
yes it can be done. get a suction pump that will reach down to the bottom of the tank, and suck it out, filtering what is in there to get as much crud out of the tank as you can.
then you can put the filtered fuel you took out back in and top it off.
set your pickup from the transfer pump 1-2 inches off the bottom of the tank, and send it through a water separator/filter before the pump.
not sure what algae conditions are in Washington, but here in New Jersey i still have about 100 gallons of 13 year old fuel left in my tank i use in the 88 in the winter.
once i get rid of the high sulfur fuel in the tank i will be filling it up with ULSD for use in all the diesel trucks.
go for it, just use a 10 micron filter/separator before or after your transfer pump.
I've used a small 250 gallon fuel oil tank for years... for both the truck and tractor... if your afraid of algae, put in some biocide.
I'm using a cheap 1" water pump as my transfer pump.
a pressure relief valve is on my discharge side of the pump/filter, returning extra fuel back to the storage tank, when my nozzle is not open/filling the vehicle.
