The project begins, 12 Volt Conversion & Rewire
  #61
Old 02-16-2015, 10:30 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Victor,
Either bring them by my place and we can straighten them or you can buy similar carriage bolts (head won't be as flat and wide) at Orchard Supply.
  #62
Old 02-16-2015, 10:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Are those the radiator saddle bolts? Those didn't used to be available as repro's, but are now from the usual vendors. 8C-8125-S at Dennis Carpenter.
  #63
Old 02-17-2015, 08:28 AM
Vegas123
Vegas123 is offline
Vegas123 is starting off with a positive reputation.
Thanks for the offer Ilya!!!!!
"Are those the radiator saddle bolts? Those didn't used to be available as repro's, but are now from the usual vendors. 8C-8125-S at Dennis Carpenter."
ALBUQ F-1
Yes they are!!! Thanks for locating those bolts!! I could not locate them to save my life!
So I removed the timing gear cover and to my surprise the timing gear that I thought was going to be chewed up was not. It actually is in pretty good shape and the timing marks lined up!!!!
PLEASE if anyone out there has any experience with these kindly let me know if my thought process is correct.
When the timing marks are lined, pistion number one should also be at top dead center and the dizzy pointed at the #1 piston??
From the picture you cannot see the timing mark on the small sprocket but its there.
  #64
Old 02-17-2015, 11:51 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
The gears look okay. But is the woodruff key gone?
Or broke and slipping the gear on the shaft? A back
fire when trying to start an out of time engine can
shear the keys. I have seen this happen. I can't tell
if this is the case from your pic. But something don't
look right there.
  #65
Old 02-17-2015, 02:29 PM
Vegas123
Vegas123 is offline
Hi Artic Y Block!!
As far as I know the key on connected to the Harmonic balance.
As it was pulled off the key was attached to it.
Is is it a separate part?? Should of it stayed in and the H. balance should have come off on its own??
I will post a pic of it today.
Victor
  #66
Old 02-17-2015, 03:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There has to be a separate key for the crank timing gear, or it would spin. Did you remove the crank timing gear, or pull it forward? I too was surprised to not see it, because the slinger should be engaging it. The damper likely has a separate key at a different location (out of sight in the pic).
  #67
Old 02-17-2015, 05:34 PM
arctic y block
Originally Posted by Vegas123 View Post
Hi Artic Y Block!!
Victor
I am having a very hard time understanding any of this post.
Like what??? When you take the balancer off there should be
like a half moon key to hold it from slipping. Maybe a square
key. IDK for sure. Than the same key or another to hold the
crank gear. This I am pretty sure would be a half moon woodruff
key. They can and do shear off flush with the crank and can be
hard to see. If any of these keys are sheared than the gear or
Harmonic will slip. Is there a problem here with this or not?
Yes more pic's may help but only if we can see what we need
to see. It's cool to help over the net like this but we can't see
what you see. And sometimes pics just don,t show enough.
Are you thinking what I am Ross?
After rereading your post several times are you saying the
key came off with the harmonic? I don't think that is right
unless it is sheared. Are we communicating at all here?
Is the key that came off a half moon key? It could have
fell out when you took the harmonic off yes. I am so confused.
But I think we may be on to something here. This is a simple engine
so it should be simple to see what is wrong and fix it.
  #68
Old 02-17-2015, 09:13 PM
Vegas123
Vegas123 is offline
Sorry if I confused anyone. This is the first engine that I have ever worked on, so I am learning as I go! Sometime the best way to learn is to just jump in.
I now understand, I can only see 1 key and that is the key that the balancer locks into. I cannot see the key that the crank gear sits on or locks into.
When I put a wrench and turn the crank all the gears do move. It does not look like the gear on the crank is slipping? Any other way for me to check if it is? I will post more pics tonight or tomorrow morning. My computer is acting up at the moment.
Thanks Guys!!
  #69
Old 02-17-2015, 10:27 PM
idahoal
idahoal is offline
idahoal is starting off with a positive reputation.
Check your compression.if its good,or even decent,it will run.check the gear on the dizzy.same tooth count?i have seen kung foo breaker plates with incorrect machining cause your very same issue.
  #70
Old 02-17-2015, 11:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think I'd get a puller and pull the crank gear, so you know whether there is a key for the crank gear. With the pulley on and the bolt tight, the gear might not slip all the time, but it only needs to do it once. You might be able to look in the groove and see that it's there, it's not a real long key so maybe it just sits inside the gear.
  #71
Old 02-18-2015, 07:36 AM
Vegas123
Vegas123 is offline
Idahoal: I will check the tooth on the Dizzy later today. I just had it rebuilt and tested by Bubba's. Hey but you never know maybe it lost a tooth. Thanks for your help!
Albuq f-1: I will see if I can have my buddy come over with his puller just to confirm that those keys are there. I also think that they sit inside of the gear but its better to be 100% sure.
Will keep you guys posted and thanks for your time and input!
  #72
Old 02-18-2015, 09:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The crank gear can be VERY hard to pull without damage, if you can possibly look in there to confirm there is a key you'll be way ahead.
  #73
Old 02-18-2015, 09:25 AM
AXracer's Avatar
AXracer
AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Another way to tell if the gear has slipped is the timing marks on the two gears will not line up. It's highly unlikely it would slip exactly 180*. Sound to me like the dizzy was installed off a tooth.
  #74
Old 02-18-2015, 09:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
They could still line up even if it slipped, but not at TDC on #1
  #75
Old 02-18-2015, 09:57 AM
AXracer's Avatar
AXracer
AXracer is offline
You're right Ross.
Quick Reply: The project begins, 12 Volt Conversion & Rewire
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
