no parking lights,tail lights,dash lights
#61
Well last night I had some time to mess with it after work. I can touch a jumper wire to the brown wire leaving plug C70G and the lights come on but won’t go off. I pulled the trailer tow park lights fuse #38 and the went off. I kept that fuse out and touch the jumper back to the brown wire and the lights come on and go off correctly.
#63
'95 F350 Running Lights, Instrument Cluster out
I'm pulling my hair out trying to find the solution to this problem. At first, it was sporadic. The running lights would come on with a good pothole but now they never come on. I don't think I have turn signals nor tail lights, either. I'm pretty sure it's a lose wire someplace, but where? Any ideas?
#64
#65
Fix for park lights dash lights
Well. For 2 years i had no running lights i did a lot of searching from seriously bumper to bumper. Pulled my entire dash relays GEM cleaned every darn connector and still no bueno. Ended up finding the brown wire that powers park lights had rubbed through the loom by the rear bed cross member by rear driver shock. Soldered new wire together wammy good to go
#66
#68
#69
Working on a 04 f650 rollback lost running light on rear while checking harness along frame must have shorted wire because now running lights on cab and dash are out. Any help would be great
See what fuses are blown out and report back. Till then I will see if I can find any diagrams on it.
#70
#71
I cannot find anything common with the exterior lights and the reverse lights, except the location of their wiring. It all passes through some connectors that are close to each other on the driver's side under the dash. I would inspect the wiring carefully, mice may have chewed through some of the wires over there.
#72
try fuse #17 thats what mine was had already replaced the headlight switch $100 DTD checked the fuses with a tester and all looked good until I took them out one by one # 17 was it all is good for now hope this helps someone look at all the fuses before replacing expensive parts
#73
I need help please my tail lights parking lights and dash board lights stop working my turning signals work my brake lights work and my headlights work fine I checked all fuses are good I even switched out the headlight switch with a new one and nothing.what can this problem be can someone please help me
#74
Did you figure out your problem cause mine doing the same thing
[QUOTE=jerrysrios;14930254]I need help please my tail lights parking lights and dash board lights stop working my turning signals work my brake lights work and my headlights work fine I checked all fuses are good I even switched out the headlight switch with a new one and nothing.what can this problem be can someone please help me[/QUOTE
did you find your problem?
#75
