No Tranny Reaction. Solenoids??
I have a 94 F-250 4X4, with the 7.3L IDI Diesel. It drove fine, shifted hard once. Then, while driving it all gears just stopped. No gear works anymore, and you can run the Transfer Case through neutral while the transmission is in park. I pulled the pan on the transmission, and found a bolt from the center of the valve body laying in there, I put it back in (it wasn't stripped) and the tranny still didn't do anything. I don't think that it is the torque converter because it isn't discolored. Could it be the Solenoids? My neighbor told me it could be that the coast solenoid is stuck open. When driving before this happened, when I would let of the gas, the truck acted like it had a jake brake on it, and bogged down hard. Right now, I have no idea what to do, I am not a tranny guy. Any help would be greatly appreciated. Thank you.
There is a neutral safety switch on the transmission that does not allow the Transfer case to shift through neutral while the Transmission is in park. The transfer case has (in order from front to back) 2wd, 4wd high, neutral, 4wd low. With the transmission in park the transfer case should not be able to run through neutral, or from 2wd to 4wd low. However, my truck will.
What should I investigate? I am not a Tranny guy, and I haven't done anything with a Transfer case before.
If the transfer case failed and is causing the truck to not move, the transfer case also would cause the park gear in the transmission to not keep the truck from rolling. You could test this by putting the transfer case in 2 high and the transmission in park and try moving the truck by hand. One person could probably move the truck on a hard cement or asphalt surface.
If a failed transfer case was the problem though, the transmission would probably grind when placed in park from a gear with the engine running.
on
I have done it on numerous OBS trucks.
I disagree. The transfer case should be able to shift into Neutral or 4wd without shifting to neutral. It can be done on Park. Assuming it's a manual shift transfer case. There is no interaction or feedback from/to the transmission Neutral safety switch.
66Charlie
01-25-2013 09:47 AM
Katmandu
11-19-2008 08:38 PM
silencedogood
06-06-2005 09:40 PM
