Rear Differential
Old Dec 23, 2014 | 08:00 AM
DSMMH's Avatar
DSMMH
I'm thinking the U joint possibly came apart and the subsequent vibration shook it to pieces or something came loose inside and got between the ring and pinion gear. That had to be a very severe load instantaneously applied to shear the pinion shaft and rip the pinion bearing cap right out of the housing.
Ed
Old Dec 23, 2014 | 08:26 AM
87crewdually's Avatar
87crewdually
Sheered pinion gear. Wouldn't have happened if was a dually. Can't always expect a SRW Dana to hold up compared to a DRW Sterling. What and how often is he pulling heavy?
Old Dec 23, 2014 | 09:07 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I want to say he purchased this truck with over 200k on it so there is no telling. He pulls his 5ther quite often.
Old Dec 23, 2014 | 02:42 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
He didn't take any pictures but he said it looked like a bomb went off inside. Total damages parts and labor $3750.
Old Dec 23, 2014 | 02:56 PM
cheezit's Avatar
cheezit
Usec unit from a local wrecker. There easy enugh to swap
Old Dec 23, 2014 | 03:28 PM
87crewdually
Used one sell for about $1,000. Couple of hours time and he'd be down the road. Far cheaper. Just make sure he gets the correct ratio. Check the axle code inside the door jam and make sure it matches if he's not sure of the ratio. This is mostly important if it's a 4x4.
Old Dec 23, 2014 | 04:00 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I offered to drive down to Dallas and haul them back to Tulsa, but it's already at the Ford dealership getting worked on. If they were here when it happened I would be glad to knock it out for him.
The crazy thing is he just had the pinion seal and fluid changed less than a year ago.
Old Dec 23, 2014 | 04:04 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Which DFW dealer?
Old Dec 23, 2014 | 04:10 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Originally Posted by texastech_diesel
Which DFW dealer?
Auto Nation in Burleson?
ColtM4
2004 - 2008 F150
Jun 24, 2005 04:59 PM
TMartinLVNV
Jun 2, 2005 09:35 PM
14u2nv
Dec 28, 2004 06:57 PM
OC2SNOW
Dec 8, 2004 06:00 PM
