Figure this truck out
What year is it? Cab is not a 67. Looks like a 68 that may have been titled as a 67 as some states went by year of sale vs model year.
Rare 1967 F250 with original camper top
I think I answered my own question: Looks like at some point the 68+ heater controls were added. And probably the reflectors are added too.
'67 heater controls used aircraft-style pull ***** instead of sliders. I also don't think that style of gauge bezel was used in '67 but I could be wrong and that part is also easily interchangeable.
Well according to our main parts guy...
You can use 1968/72 F100/750 doors on 1967 F100/750's since the hinges, outside door handles and the striker plates are the same.
1967: You push the inside handles forward to lock the doors. 1968/72's have door lock *****.
1967 F100/750 only: Door shells, inside window and door handles, vent frames and handles, door lock remote controls, window regulators, door latches. door lock cylinder rods, armrests.
And: Firewall, dash, radio, heater, brake & clutch pedals, bracket they suspend from under the dash. Master cylinders, P/B boosters, brake differential proportioning valves, low brake fluid warning lamp switch, ignition switch.
1967/72 F100/750: Same door related parts: Weatherstrips, upper/lower door hinges, glass, door lock cylinders.
