72 x F100 Chassis is wider under the 54 x F100 body
What is the F100 > 1954 front & back track widths ?
Just looking at mine front track ( 1972 chassis under 1954 body ) looks too wide hubs almost out past fenders ! Wheels will need to be massive negative offset not the look Im after.
Will it be easier to replace the front end to get it lower and narrower or will
that cause the track widths to be to different between front and back ?
I'm afraid the twin I beam frame/axles you have under a mid 50s truck is the wrong combo, way too wide.
Havi are you sure? The reason I ask is I have a 57-60 axle in a junker 56 here and it looks right. I have never measured it width wise but it does give it a 1" drop over the 53-56 axle
Does anyone have the specs on these things , apart from finding one and measuring it ?
Measurements seems to be the same ?
I looked up and read posts regarding Jag IFS , looked up the specs , cant seem to find one telling me the space between the
( 1972 chassis has 870mm to outside edge or 34-1/4")
Anyway the posts I found say Jag track 64" & the 72 = 65" this doesnt seem like a lot ?
The only other thing that might make it look too close to the edge of the fender is they are 1976 disc brake stub axles ,
but the track measurement is the same ??
Signed going crazy
Signed going crazy
Nicxt44191
23
05-05-2019 12:49 PM
larry53deluxe
02-06-2012 07:56 AM
