Brake Lamp Switch Weak?
Old Dec 19, 2014 | 04:12 PM
Tedster9's Avatar
Tedster9
Noticed the brake lights take a pretty good pedal to illuminate. Will a new switch be faster? Cleaned up the old one and swapped it over to the new M/C a while back.
C1AZ-13480-A
Old Dec 19, 2014 | 04:40 PM
jowilker's Avatar
jowilker
Shouldn't the power is on or it isn't. You may have a bad ground that is causing some delay. You will have to dig that one out.
John
Old Dec 19, 2014 | 05:38 PM
Tedster9's Avatar
Tedster9
That's what I figured, it's just a pressure switch. Part of it, I think is that modern brake lamps illuminate before the brakes are even hitting the rotors.
Once I get the brakes bedded in and make a final adjustment for wheel drag, the pedal should be even higher, that may help.
Old Dec 20, 2014 | 12:09 AM
resonateur's Avatar
resonateur
Ted:
Yeah, modern brake lights come on from an electrical contact adjustable at the pedal arm. You can change over to this system (modify or purchase aftermarket kit) if you want a quick acting light. The old style as you mentioned, is a pressure switch, which takes a certain amount of pressure to activate. If you're using Dot 5, silicone brake fluid, those switches will tend to fail much quicker and regularly.
Old Dec 20, 2014 | 07:24 AM
P38fighter's Avatar
P38fighter
Actually Ron Francis sells a low pressure brake light switch. It activates in the 20- 50 pound range - most cars are in the 60+ range. I have one on my truck.
Old Dec 20, 2014 | 09:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1AZ-13480-A (replaced 0A-13480) .. Brake Lamp Switch (Motorcraft SW-24) / Available from Ford & auto parts stores.
Applications: 1940/66 FoMoCo vehicles.
Connecticut Calvin
24
Feb 3, 2016 09:17 PM
PRIZMBLUE
Mar 6, 2011 05:52 PM
john smith jr
Aug 26, 2010 10:45 PM
ksmith203
May 16, 2007 10:27 AM
proteks
Dec 9, 2004 01:59 PM
