2003 Expedition with rock-hard suspension
Our 2003 Expedition (4.6L, non-air suspension, 2WD) drives like it has 80 lbs. of air in the tires... We feel every bump in the road. Very harsh ride. We've owned it since 2005 and it now has 110K miles. Tires are General Grabber HTS with proper amount of air.
I've scanned the posts about replacing the struts and the majority seem to replace the struts when the bouncing gets excessive. If I push down on all 4 corners, it only rebounds once. No squeaking or unusual noises.
Anyone else have this same issue, or is this normal?
Are the struts/shocks stock? If the original owner changed them within the first two years, they could have put a higher performance shock on that's stiffer then stock. I agree, that if the truck settles with depressing the corner, just once, the shock is probably good, just stiff.
There are newer units that have some adjustability to provide a variety of ride comfort.
How much psi do you have in the tires? My tires are 65psi max. Last week i was low on all 4. So i filled to 56psi in all tires. The truck was noticeably rougher over bumps just like you describe. I lowered back down to 50 and all good again. Other than that as mentioned, alignment or maybe a front end issue.
Thank you for the replies... I plan on getting it up in the air over this next week to see what is on there, perhaps they were replaced within those first 2 years. I've used the Monroe QuickStruts on another vehicle in the past and had good results.
Tire pressure on the stock-sized tires is at 35, following the suggestion on the driver's side door jam.
I'd say that's a pretty normal ride for the Expedition. It's likely that the tires just ride rough the older they get. If you bounce the suspension up and down and it rebounds the same as it ever did then that eliminates that. At your next tire change try the Michelin LTX's tires. I've been very happy with those on the Expy. If you're going to change the struts out I would recommend the Monroes or KYBs for comfort. The Bilsteins will be very firm.
-Mike
Michelin LTXs at Tire Rack
-Mike
