48 Steel's Built Thread
#31
I had to use the small pocket hidden hinges due to the smaller size of the front door frame.
Bear Claws with Electric Solenoid's
___________________________________________
48 Ford F1 Darkside
46 Ford Tudor - Street Rod
"The guy that says something can't be done should stay out of the way of the guy doing it. "
48 Ford F1 Darkside
#32
After installing the hidden hinges and fitting. Now to complete the chop of the top of the doors. The bottom of the doors were fitted to the door opening and then I matched the top on the doors to the opening and tacked into place for fit.
_______________________________________________
48 Ford F1 - Darkside
"The older I get the faster I was"
#35
Reversing the hood opening was a challenge. After doing research I was able to find 4 other F1 that had reversed hoods. There are after market conversion kits for the 56's but nothing for the F1's.
The front latching system came out of a mid year Dodge Van.
_________________________________________________
"CAUTION - The nut behind the wheel has a screw loose"
#38
There are a couple of the pictures that I included here that shows the rear of the hood where the hardware is attached. If you notice I attached my hardware to the original rear hood cross brace where the original springs were attached to the hood.
Here are 2 pictures of the hardware and how it is attached to the hood.
#41
#43
#44
