injectors I think???
Old Dec 13, 2014 | 10:22 AM
GondolaRides's Avatar
GondolaRides
hey guys, Im getting really hard long starts and then it'll chug once it turns over and blows a ton of white smoke. also its not pulling very well. even a light trailer really bogs her down and the throttle just feels kinda dead. also now it feels like there is no difference in-between the settings on my chip. any ideas would be appreciated. just turned over 200k and i don't think the injectors have ever been done.
Old Dec 13, 2014 | 10:33 AM
DarkStarMedia's Avatar
DarkStarMedia
I would check your turbo and glow plugs first.
Richard
Old Dec 13, 2014 | 11:06 AM
GondolaRides
like air leaks? glow plugs are relatively new. I have gone through a couple relays though.
Old Dec 13, 2014 | 11:17 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
What kind of glow plugs did you use. Might not be a bad idea to test them and the relay. You could plug it in also to see if it aids in cold starting. Check the uppipes and manifolds for leaks and or soot. Also check the fins for damage and free play.
Old Dec 13, 2014 | 12:29 PM
DarkStarMedia
Basically what nick said. Do you have a turbo guage?
Old Dec 13, 2014 | 01:28 PM
GondolaRides
They are oem plugs, and I do have boost gauge.
Old Dec 13, 2014 | 01:32 PM
GondolaRides
Also I rebuilt the turbo not to long ago and fins and stuff is all good. I re tightened the bolts on the up pipes after one fell out. As far as I can tell they aren't leaking anymore but I will get in there and take a closer look
Old Dec 14, 2014 | 12:16 AM
DarkStarMedia
When it boggs down under load and smokes, what rpm and boos pressure are you getting?
Old Dec 14, 2014 | 07:10 AM
GondolaRides
on the highway around 2000 i might be boosting around 5. it won't downshift until i take it out of OD and then seems like the most i see is 10-12.
Old Dec 14, 2014 | 08:34 AM
DarkStarMedia
Those numbers sound low to me but others can chime in.
Check your up pipes and all tour boots and manifolds. Also check your map line.
Richard
Old Dec 15, 2014 | 12:32 AM
blue66tang95f150's Avatar
blue66tang95f150
My stock 7.3 with just a 3" DP will get 10psi at 2k, 15psi at 2500, and 18psi at 2800. I don't rev it any more than that so I dont know if would reach 20 psi or no.
Old Dec 16, 2014 | 03:44 PM
Awitte58's Avatar
Awitte58
His signature says he has bellowed up-pipes, so that shouldn't be an issue unless the mounting bolts are loose.
If your GPs are all showing the correct ohms so you know they are good, but you are going through a few relays. That makes me think the Under valve cover harnesses may have some issues internally.
Are your batteries in good condition and the connections are all good? Corrosion can cause some finicky stuff.
roostercrows
Mar 19, 2018 06:26 AM
sammydiesel13
15
Oct 18, 2012 06:38 PM
wycowboy
Feb 19, 2012 01:40 PM
blueeyedfordguy
General Diesel Discussion
May 4, 2010 09:48 PM
fordguy_460
Aug 18, 2009 04:28 PM
