Some Good News for California 6.0 CARB
I was reading in tone of the Diesel magazines today and guess what I found.
BPD got an approval for the EGR cooler. So if you happen to be
stuck living with the California CARB rules and have a cooler
that was replaced with one from BPD you may want to check with
then to see how the change can help you.
From >> BulletProof EGR Cooler, Square, Ford 6.0L, Lifetime Warranty
BULLET PROOF DIESEL SQUARE 6.0L EGR COOLER
STAINLESS STEEL TUBING THAT IS STRONGER AND MORE RESISTANT TO FATIGUE AND HEAT STRESS FAILURE
ALL JOINTS AND SEAMS TIG WELDED
QUALITY CONTROL ENSURES DIRECT FIT EVERY TIME
CALIFORNIA CARB# D-730
List Price: $427.88
Manufacturer's Direct Price: $350.00
You save $77.88!
Sean
List Price: $427.88
You save $77.88!
Sean
To be honest, I'm not sure the smog guys can even tell the difference. The thing is buried in there pretty good. I've had one for a few years now. It has been through two biennial smog tests. The guy I go to visualizes the CCV, EGR & Cat, does opacity (smoke) snap test & plugs into the OBD 2 port to look for CEL.
I guess it is good news in case you ever get an inspector who really, really knows or a referee station.
Sean
That's the million dollar question - what do they actually do, other than look for codes, at the OBD port. Just to be safe, I always switch back to the stock tune. I had to get rid of my sneaky up-pipe (appeared stock but I welded a disk in) because it would set a code with the stock tune.
Josh
From what I have had the fun time to read on the internet (we all know that is 100% the truth)
YES they do. Also the road side stop cops do that too.
One more reason to never live there and only visit.
BTW do they hit you with income tax for any time in
the air over that place like with pro sports?
Sean
Sean
So far in Washington State and in limited areas.
Snap test and maybe a peek under the hood to
get at the battery in my case. They were not
getting enough signal to drive the computer thingies.
I think it looks for some ripple in the 12VDC ???
I bet that the tech does not know or really care.
They just want you cash.
Sean
Sean
Sean
Sean
I have a couple buddy's that have had their trucks emission tested cleaner with an EGR delete than with one installed FWIW.
I will say the one thing you will need, especially in parts of Weld and Larimer County in Colorado is a catalytic convertor. Guaranteed they will look for that.
As for EGR cooler it's hit n miss whether they pay attention. If you have a PCM strategy that doesn't throw a CEL for the delete then you're even more golden in that regard.
I'm glad I'm in an emissions exempt location and do not have the hassle of that yearly.
Josh
A few years ago Texas was going to adopt emmissions testing. Lots of controversy.
The State and Feds forced it thru and spent 1million dollars in Port Arthur building a test facility, dyno the works.
They invited some of us to bring some cars in to show us the test. and prove how accurate it was. Well this one guy hung back until he was the last.
He brought in a 62 chevey. They told him there was no way that car would pass. He said shure I know it is not compliant but humor me and let me test it. This way will know how acurate the test is.
Make a long story short his car passed with flying colors. Then he introduced the 4 men with him they were the leaders of the opposition to the testing laws.
He informed the state officials running the test that he had deliberately sabotaged the car so there was no way it couldpass and their test was an outright lie.
All facilities were closed down within 3 months and never publicly opened.
The legislation was withdrawn, killed what ever they called it.
They had secretly filmed the whole thing and that was what they showed the state congress.
Built 3 brand new test facilities for gas testing no longer allowing dealers and small shops to handle the testing as they had before. Only a few diesel shops could now do testing and they charge $60-120 per test. Gas cars are a flat $25.
Long story short, they have gone out of their way to make cars fail. (brisk acceleration, pumping the throttle, power braking at idle) Biggest scam has been testing gas caps. It got so bad every parts store in Fort Collins, Loveland and Greeley were sold out of gas caps.
Josh
They do a CEL test, visual under the hood and under the truck for a exhaust visual.
Then they take your 60 bucks, five minutes later.
Cars, another story.
