96 Ranger- Starts but will not run
I've got a 96 Ranger, 2WD, 5 speed, 4 cylinder. The truck died a few days back, I had it towed home and discovered some bad vacuum lines, some off and some cracked. I replaced them all and can now start the truck but it will not run. I can keep it going with starter fluid, but it will not run more than a few seconds without it. I've replaced the catalytic converter, IAC valve, cleaned the MAF sensor, and cleaned the throttle body the best I could without removing it. Still, no idle without starter fluid.
I'm stumped. I've tried to pull a code but it is showing none. Any ideas?
Thanks for any help.
BucksCountyCountryBoy
07-26-2012 04:43 PM
D_J_G
1983 - 2012 Ranger & B-Series
03-23-2003 12:29 PM
