My 1987 ranger 2.9L xlt is having problems with working directionals and heater when started but in accesory mode they work fine idk what the problem is just got a new alternator and now they r not working
any ideas?
i did have flood lights installed by my grandfather we r checking the wires for those and the wires that come from alternator
I also have an 87 Ranger xlt 2.9 Great little truck.
Simple test. Turn the key to accessory & pull fuse 5, the turn signals should quit working. If they do you need to test for a cross in the ignition switch.
To test the ignition switch remove the 2 lower screws from the plastic steering
column shroud, squeeze the lower & remove the upper.
Remove the electrical connector from the switch & connect your ohm meter to pins A2 & BATT. If you can make and break the circuit by turning the key from off to accessory replace the switch its shorted out.
