zf5 with a 300 inline 6?
on
Pros: Tougher than the Mazda 5spd od trans, has Overdrive and a decent Granny Gear.
Cons: Hard to argue against a case iron case. Transmission crossmember modifications, Driveshaft(s), Speedo Gear spot(?).
On the 300, i know the clutch is different too. It's bigger and the pressure plate is thicker.
I have a 2wd unit I have and want to install in my 4wd '78 f150. Not sure I want to do the internals as the process is quite involved...
300FOREVER
04-09-2021 06:13 PM
Col Flashman
17
01-11-2005 10:38 AM
PAUL_2
07-27-2001 01:49 PM
