New 58 C series owner- Auto transmission, Brake,Power steering and tire and wheel options
I just picked up a 58 Ford C series cabover and had several questions. Same body style as the 60-83 year cabover. I have been into 60-62 Ford/Mercury cars for the past 10 years and have zero knowledge on these trucks.
Transmission- Engine appears to be a 292 or 312 Y block with 4 speed OD. I would like to add an automatic transmission as the old school manual shift is a bare. I haven't driven a beast like this since I was a kid. Are there any beefy Auto transmission options out there? Eventually, I will replace the engine as well but not near term.
Tires/wheels- Tire costs are expensive as they are 9.00 R 20 which don't appear to be too popular anymore. Wheels are split wheel which require tubes. Am I better off replacing these wheels in the long run or keeping them? I'm not up on the reliability of these (I have heard of widowmaker wheels and hopefully I don't have those type of wheels).
Brakes are standard hydraulic type brakes. Any upgrade option aside from the expensive air brake route?
Power steering- any simple options to add power steering? Can I buy a pump that mounts to base of steering shaft? I have seem after market RAM assist units but not sure how they work.
Thanks in advance and sorry for all the questions at once.
What C series is it. Dont think I ever came upon a C cab with a small block
more like a 302 or 332 Y block. The automatic was Transamatic (spelling) with is a six speed Allison. Power steering is a little complicated on these, better
off finding a set up in a junk yard they are out there- any year C cab unit
will fit. Wheels what kind of hubs? most are 20" Daytons where as you can
but 22.5 tubless anywhere. Or disk rims on the light trucks like C600 or
something. My ole brains telling me I think widowmakers were already
phased out by then...And then If your in the C800 C900s can be had with
10 lug disk rims -dont know what you have.......as you said "expensive
air brakes" you got that one backwards= juice brakes are the expensive
worthless ones.
worthless ones.
I'm not sure which model I have. Challenge is the title says 1958 Seagrave as it is an old fire truck. I plan to take the ladder off and make it a car hauler. (yes I know it's a shame to do that). Tried to decipher VIN and only got partial information. Here's some pics of it along with pics of wheels.
Ah the picture clears a lot up. What you have is a C800 or C900- I say
C900 due to the front axle (the heaviest one). I give 100% its got
a 332 Y Lincoln with a 5 speed Clark trans. Or being 1958 Its possible
it may have the new 401 /534's which are quite massive.. Yesterday I took a
look at my power steering just to (update my brain). Quite simple
set up; all of it is a bolt on, bolted on the left frame rail. No creeper
involved. Again, It never ceases to amaze me why in hell, citys and
towns spec a truck of this caliper with out air brakes & power steering
just for the sake of budget, like buying a new Caddy or Lincoln without
A/C power windows and seats??
This weeks juice brake epesode. Wife smashed another fender in
Wallyworld light pole; brake pedal went to the floor? Rotted brake line in a
5yr old Escourt? I know women aint truckers but what if it was a baby
carriage. Heres ours C900
as I said its a real simple bolt on system. I think you will have to fab up
a pump bracket cause the 332Y bracket will be a hard to find item. And most
later C models have power steering.
sam
1957/63 Ford truck parts catalog lists the 292 for 1957/63 C500/700. 302/332 Lincoln derived Y blocks listed for 1957/63 C700/900.
So, there's 3 possible engine sizes for a C700. 312's were only installed in Passenger Cars.
The only 4 speed available was the Warner T-98, it does not have O/D
OP: Your truck is registered by its specific VIN .. the engine code is the 4th digit, post what it is.
To the OP, how soon are you wanting to be using this truck?
I really love the looks of that truck, If you are not in a hurry you might keep your eyes open for a newer parts truck. even if you find one with higher miles there are many part like brackets that more miles don't matter on.
And I agree with the other poster that Air Brakes are the way to go if you get that option. That is why I was recommending the part truck idea.
I'd look for one with close to the same weight rating on the axles.
Who know s you might just find one with air brakes the wheels and tires you want.
My 94 F700 has the standard frame with and I swapped a air ride axle and suspension from a Freightliner 120 OTR tractor under it and it drive so nicer now. It looks factory if you didn't know F-700 truck didn't come with air ride in 1994.
That is just an example of what can be done.
flowney
27
12-09-2020 10:07 PM
old58
61
08-18-2015 03:37 AM
