Jolly Green Giant...2015 F-350 KR DRW
#9092
Received 3,991 Likes
on
This is a window that I installed and the cedar trim around it......
I am in progress of replacing all windows and the door to the deck. Then painting the house. Already replaced the roof.
The two PVC pipes are the cold air intake and the exhaust for the gas fired furnace....
The electrical service with meter......
To the right of the electrical meter is the air intake and exhaust (metal pipe) for the tankless hot water heater, gas fired.
Further to the right is the vent for the bathroom exhaust fan.
Blue colored disk is a plug from a prior hot water heater exhaust vent.
To the left of the electrical meter box is the piping for the A/C unit...... And cables from the outside TV antenna.....and power for the A/C unit and for an outside electrical outlet.
That is about it......
The siding is being sanded getting ready to prime and paint with two coats.....
#9094
on
Good point though..... I'll work on that.
#9096
on
I wanted to put a clear sealer on it....... But Lynn wants a dark gray semi-gloss paint........
#9097
I concur with using ceder, but only if the majority of the job is done that way. If the rest of the siding is something easily eaten up then cedar trim becomes irrelevant.
Now yes, my opinion is at some point you should clean up the appearance of that unsightly wall of pipes, vents, wires, etc. Perhaps covering it all up with a screen that affords the proper ventilation?
Admitting to my faults, I really need to replace some very weathered siding surrounding my house... however other more important projects must come first.
Military (retired pay) ain't what most would think of as generous. Nor are our social security benefits.
Go Army, beat Navy.
Go Army, beat Navy.
#9098
on
Go Army, beat Navy.
Go Army, beat Navy.
I will put some thought into the vent pipe mess......
I wanted to replace the siding, but funds would not allow it.
#9099
on
The House Project is progressing.........
Notice the Black Pipe railing... Sooooo Nice !!
Yes, the pipes will be addressed !!
The back of the house chimney is coming down
Front of house. Basement....North/west corner. Trim to follow....
Time to get back to work.........
#9101
Aren't you supposed to have paper flashing around the window first? That's the way it's done here anyway.
#9102
Keep up the great work Roy
I started on my indoor house project today....... The wifey has been patiently waiting since spring.
#9105
on
