Jolly Green Giant...2015 F-350 KR DRW
#8431
Received 5,158 Likes
on
#8432
Good morning everyone!
Looks like we'll have to put off our 2 night trip this weekend due to heavy rain and thunderstorms Saturday. Some are predicted to be right over the State Park that sometimes floods with heavy rain. 3 to 4 inches is forcasted.
#8433
Roy, those shackles can flip on their own if you lift the whole trailer at once. I've had mine flip a few times using the Level up system to get all 6 tires off the ground at once. Did you ever have all 4 tires off the ground at once? If so, that's likely when the shackles flipped. Also, to fix the issue if it ever happens again, you just use the front legs. On level ground, run them all the way to their max extension. The shackles will flip back with a bang. It will literally sound like a gun going off. The first time it happened to me (when I first got the RV and had all 6 wheels off to get my GY's mounted up), I removed a bolt from the equalizer and flipped it back by hand as I didn't realize what happened (or the easy way to fix it). When asked my buddy at XLR about it he laughed and said it happens all the time and even many experienced RV tech's don't know the quick fix. He told me about the raising the front end trick and said he's done it to a few guys to scare the chit out of them. He said he has them kneel down and watch the shackles and says, "tell me if anything changes" as he giggles and raises the nose... then BANG! and they have a heart attack and roll backward... LOL
#8434
Rodney is 100% on the money here Roy. Both my trailers shackles will flip if all 4 wheels are off the ground at once. To save the hassle I use a strap from the front axle on both sides to the frame. Then everything lifts happy. I have had the dump trailer shackles flip once empty on severe situations like backing into an uphill driveway. Doubt it would do it loaded, or that the camper would as the springs will be flatter and essentially longer.
#8435
Received 3,991 Likes
on
Thanks for the lesson / feedback.......
The first time I noticed the problem, the trailer had been at a suspension shop to correct the bad tire wear problem. (which they didn't). So that is when it happened and they were too dumb to correct it.
#8436
on
Today is not the best of weather........ expected to snow late today.....
Temp is only 34°F...... A wee bit chilly, but ok.
I need to finish pulling the underneath covering off......inspect / neaten up the rats nest / add insulation.........
#8437
Damn...that is crazy in 2 years.
I was thinking that your trailer was fairly new at just a few years old.
But with all the problems, was second guessing myself, that no maybe you bought it used and well worn already. Sorry its such a mess under there for you buddy.
#8438
on
Craftsmanship and pride in doing a good job is hard to find ..........
#8439
Well, Have you seen the photo's of Roy's inventory in his basement? Probably 5K# overweight....
Any hits on your old TH for sale Roy? If not, time for an insurance claim....
#8440
on
The Montana is a little under gross weight..... Last summer I weighed it when fully loaded for our summer trip. Just under 17,000 lbs, which included about 3,000 lbs on the pin.
#8441
It's easier to spot on a tri-axle Roy. On mine, if the shackles get flipped, the center and rear tires get so close they are almost touching while the front to center axle clearance gets wider...
#8442
on
More work accomplished this morning before it started to rain around noon........ buy 1600 or so it was snowing and sticking on the grass.
Monty..... I checked the lug nuts on the 9/16" studs with the alum wheel....... No problem.
More underbelly covering removed.......
The 2nd MORryde rubber spring is damaged....... this is on the starboard side (passenger side)
After it rained awhile....... The snow started......
I wonder what tomorrow will bring..........
#8443
on
I was forced to purchase a new toy today......
I was in North40......a Ranch & farm Supply store......I was looking at the DeWalt battery powered Impact Wrench....... 1200 ft/lbs of reverse torque. Charger and two 5A batteries. $449 ($393 from Amazon). The sales guy suggested I look at the new Milwaukee 1400 ft/lbs Impact Wrench..... Charger and two 5A batteries..... $419.......PLUS $100 discount if I spend $25 on a Milwaukee accessory. There is always a small toy needed........ So the Milwaukee kit cost me $320........
#8444
on
The 2nd MORryde rubber spring that I ordered, arrived today.....
Later, the sun came out and most of the 6" of snow is melted..... I'll be back to work tomorrow on the Montana........
#8445
Those impact guns are great! My son runs a Peterbuilt truck, and he likes to toy around with some of the older ones. He recently bought an old one that has set for several years. He got the one step down Milwaukee gun, and it took a rusted lug nut off of that truck that his 1inch pneumatic gun would not budge. Be warned that gun will twist the studs off of your wheels if you are not careful!
