Jolly Green Giant...2015 F-350 KR DRW
#8416
Received 3,988 Likes
on
Roy, before you get too far along, something has been bothering me about the wheels. If you can, test fit the wheel and then put on a lug or two. I've read that some that went with the bigger studs and then got new lugs, the lugs didn't have quite enough room the seat completely. The stud was wider that what the wheel was actually made for and the new lugs, being slightly different bevel, didn't sit well in the lug well on the wheel and would loosen. Just wanting everything to work out well for you when this is done. Hopefully all is fine, just wanted to mention it so it wouldn't cause you any troubles.
Man, you are making me want to do this so bad!
Today I spent most of the day resting. Trying to give my left eye some healing time.
Tuesday I will be very busy all day with Foothills Christian School annual Banquet........ T.C. Stallings is our speaker........Warroom......
So, It will be Wed before I can check...... I will check.
When you are ready...... Line up three or four installs in your area and I'll show up to help you and do those.......
#8417
as long as the wheels are steel there shouldnt be a problem, ive run into cases of that with the aluminum wheels, they crack sometimes too when side loading them by backing up and turning sharp. gotta re torque them often and check lug seats on wheel for cracking.
#8418
on
#8419
on
Good morning....... Just a thought........ If there is a lug nut problem, I'll just use super glue.......
#8421
on
Hi Tim....... I'll bet a dollar that there are people that would do that...........
I have to go...... Busy day with the FCCS Banquet........
#8425
on
#8426
on
Just removed the Starboard side MORryde Rubber Spring........ It is Also Damaged....... This is F....... redictulas......
It is not very bad, it is a toss-up..... The coin fell on better safe that crash....... New one ordered.
#8428
on
Remember last spring....... I was trying to find the cause/cure for the badly wareing tire (front starboard side).... I discovered that the shackles connecting the steel leaf springs to the rubber springs were pointing down instead of up....... Installed wrong from the factory.. I do bet that this was the main cause of the failures......
#8429
I would guess that everything is being overloaded.....
#8430
How can Monty be tired of the cold? It hasn't even been cold there!
Forecast for over 70 today, woohoo!
Looks like Gerry is in for more snow this morning based on the radar.
