Jolly Green Giant...2015 F-350 KR DRW
#376
Received 3,991 Likes
on
#377
on
I agree Gerry. That is the route I am going to go.
#378
on
Winter driving
I had questions about a Dually vs. SRW in ice and snow.
I had a SRW 2001 F-350 for 3 years. In the ice and snow up to 8 - 10" the SRW did ok, but most of the time I used 4-wheel drive due to the very poor starting traction in town when there was ice and hard packed snow. I put winter tires with studs on all 4 wheels the 2nd winter. Helped a bunch. I also had 6 - 8 60Lb bags of sand in the bed.
The new DRW.......Jolly Green. As of yet, no sand bags. Factory A/T tires by BFGoodrich. I am get far superior traction in 2-wheel drive then I got with the SRW. I am driving on icy roads and roads with 4 - 6" of snow so far. I don't need 4-wheel drive.
Hummm.......Jolly Green has Limited-Slip rear end. the SRW 2011 did not, but had e-lock rear end.
#379
Yeah,
I thought that the DRW did pretty good last year as well.
I think the LS rear end helps more than the e-locker.
e-locker will disengage if you go too fast is my understanding.
#380
on
I understand, if you aren't going pretty straight, you don't want to engage e-locker.
#382
Lockers will cause the truck to tend to plow forward and not turn. That is why they turn off above 20mph. Lock the front and rear and then good luck turning at all
Sent from my Telegraph using IB AutoGroup
#384
on
#385
on
#386
SPE diesel makes software to keep the e-locker engaged above 20mph.
#387
on
I went with the Limited Slip and am very happy with it....
#388
on
#389
on
Today was another "school" day.......Had to figure out how to remove the center hub on the rear dually .........Made a tool out of a coat hanger. Long hook with handle.
Then the easy part.......put on the SS braided air lines to extend the valves to an accessible location.
WELL Worth it !!
The center Hub had to be removed to pop rivet the bracket to the hub.
WELL Worth it !!
