Jolly Green Giant...2015 F-350 KR DRW
#167
So then, Roy, does this mean that you are installing air bags under your new truck? If so, what make and model are you installing? I have been wondering if I should do this or not. With my GN, my rear drops 3 inches, and I haven't measured with my 5er yet, but probably about the same.
#168
There are control kits both using hoses from on board air tanks (ViAir) and wireless kits (Airlift).. both companies kits can control both rear bags as one or separately.
I have the Firestone kit on my 2012 dually and use the Airlift Wireless One controller. It makes a big difference in ride quality for me and my wife when towing the FW.
#169
Seems we have used both Firestone Ride rite (2535) and Airlift (load lifter 5000) bag kits.
#170
#171
My guess is that since even 18 wheelers use bags for a better ride, the truck would ride better. The "need" part is more difficult to answer though.
#172
I don't feel the need for airbags in my DRW. I loose about 2" but that is just barely touching the overloads.
Many miles with the 5er attached and I think the manners are darn good without the airbags.
#173
my DRW is close to the overloads with 1 8ft 2x4 in the back. really rough ride on our rural backroads.. the airbags give me just enough adjustment to soften the ride a LOT with a little change. then with the FW the little bit not tail dragging makes the ride better..
#174
I use my airbags for non towing related items as well. Trip to get brick pavers...no problem. Drums of oil...no problem. Firewood...no problem. I can't be seen sagging lol
#175
Received 5,131 Likes
on
No one like the droopy diapers look........
#176
Received 3,942 Likes
on
2011-2015 Ford F-250, F-350, F-450 Super Duty 4WD (Fits w/ Fifth Wheel or Gooseneck) - Load Lifter 5000 ULTIMATE Air Springs w/ Jounce [REAR] - 88396 | $332.26
Air Lift 25850 Analog Control System Standard Duty Compressor - Single Path
#177
I have them on my 13 DRW. Trailer has 2300+ pin weight and rode miserable. Back end was lower than the front. I have airlift 5000 ultimates, and they made a night and day difference in the way the truck rides with the trailer on. After installing the Airlifts, I think that Firestone has a nicer bracket to mount to the axle. I have an Airlift wirelessAir kit too, but haven't installed yet since I'm still unsure where I want the compressor.
#178
on
...and as old as Andre' is.....he has to be careful about "sagging"......
#179
on
I had to quote this, ure lucky he doesn't live closer, lol
#180
on
If I didn't tease him......Andre' would feel neglected......
