Jolly Green Giant...2015 F-350 KR DRW
#1382
Hey, I know things drift around in here and I had a thought yesterday while driving from Orlando to home.
Can it be imagined that we as a people actually had the ***** to take the nuclear option approx 65 years ago? Compare to today, our leaders have no idea what needs to be done and are scared to even talk about it.......
#1383
Received 3,991 Likes
on
Too bad we don't have Patriots in office instead of Traitors.........
I see that Mrs Traitor is officially running for King Traitor's position....
#1384
#1385
on
Good morning Sam.......
Last night I ordered an RV 9.0 cu ft fridge. The OEM one died last summer. I trust pulling the old one and installing the new one will not be a hair pulling project.......
#1386
been thinking of putting in a residential fridge.. might have to lose two drawers, which DW wouldn't be to happy about.. but she would be happier with the fridge.... decisions decisions..
#1387
on
Last summer we purchased a 13 cu ft apartment fridge and put it in the "Garage"/ Theresa's bedroom. I am going to install an inverter soon to run it on the Battery bank when we are not hooked up to Shore Power. For long trips and stays in the 5th wheel, the 2 refrigerators will be very nice.
#1388
RV.Net Open Roads Forum: Great inverter setup to run residential fridge in your RV!
#1389
on
great topic on adding a dedicated small transfer switch for the inverter output
I will read through that.
#1390
was 'easy' then.. no realtime consequences.. I also don't think it was 'we as a people', the public and press were not involved. Today things are a lot more complex. MAD works. Problem is how to contain the new players who don't know/want to follow the rules. Trust but Verify is a lot of work.
#1391
Roy, a good friend with an Airstream replaced his busted fridge last fall before he left for his annual trek to warmer climates. It was a one day exercise for him and he has a lot less room to work with than you do. Should be pretty straight forward for you, especially if you are essentially replacing like units. If you were moving to a Thermador gourmet kitchen double door freezer fridge combo it might be a bit tougher.
This might be a hair puller.
#1392
on
The existing until is 8 cu ft. The new one is 9 cu ft. Due to the insulation density, same width...depth & slightly higher. I'll be doing minor cabinet work. I do not expect any problems.
Between the RV fridge and the Apartment fridge of 13 cu ft, we will have 22 cu ft total.....
#1393
Hi Shawn......
#1394
Good luck with it Roy. I am sure you will do fine with that task... I don't see it as a hair puller, maybe a few cuss words here and there.
Getting it all set for your AWESOME, SPECTACULAR summer vacation coming up...
#1395
Hey Roy, long time no talk, I am having a difficult time locating my upfitter switch wires. I have looked all over under the dash on the drivers side and the passengers. Do you have any wisdom to share ? I would really like to hook up some extra lights but can't seem to locate the ends of the cables. Any help would be appreciated. Thanks, Tucker
